MSI H610M-E DDR4 The sound does not work after the update
omezi156702da
I repair motherboards in Russia, a lot of boards come after the BIOS update on which the sound stops working. But rolling back to previous versions through the programmer does not help. The only way to make the sound work again is to change the chipset with a new chipset and the sound starts working with any firmware. Also, if you put this chipset on another H610 board from ASUS GIGABYTE ASRock, there is also no sound. Incorrect firmware somehow disables the chipset. The problem is that the chipset does not reset the audio codec, I tried to force it to be removed, but it also does not work. This massive problem occurs for users after updating the BIOS, the sound disappears in the task manager or hangs on the VGA post code, but after firmware on the programmer we also get a non-working sound. Solve the problem in Russia, they refuse to accept these warranty cards because they blame the user for incorrectly updating the bios. I'm sure there's a firmware that will fix it somehow.
I even made a video about it a long time ago.
For Audio recovery
We would like you to try this method first.
Make sure to flash back to the previous working BIOS first
This will be on your motherboard support page
The second-to-last bios released in 2023 will be the one you want
Flashing to this BIOS will not void the warranty
If the BIOS recovers the audio, follow the steps below
Roll back to the last working bios and then update the BIOS with the Svet BIOS update tool. This has worked so far without the need for the other patched Bios to be used.
Download the tool from the link:
https://forum-en.msi.com/index.php?threads/forum-uefi-shell-flash-tool-v1-81-for-msi-boards-%E2%9C%94.343010/
Hi Alan could I also get a pm with the correct BIOS please.
PRO H610M-E DDR4​
Have you tried the new method that was developed?
For Audio recovery
For Audio recovery
Hi Alan. The tool didn't help me. I still get this on my list of sound devices. Bluetooth works but 3.5 mm jack does not recognize my speakers. Any advise?
PM sent, but not sure it will help as you have the sound device showing in Device Manager
It could be a case of Drivers not installing correctly
For Audio recovery
Hi, Alan!
Thank you very much for your job!
I installed BIOS 7D48vAC 2023-09-12 and the sound is now working.
Why do I need to follow the next steps if the sound is working?
"If the BIOS recovers the audio, follow the steps below"
So you have the latest BIOS to avoid any Intel degradation CPU problems with 13th and 14th gen chips
After the sound stopped working, I don't want to update the BIOS anymore.
Bios will update fine using the Forum Flashing tool. It has been tested and is a proven solution to the loss of Audio when doing a BIOS update on certain motherboards
Just updated the bios of my MSI H610M-E DDR4 after several years and broke the audio too.
I tried to flash back version 7D48vAC (second last of 2023 right?) but it did not solve the issue.
Also tried to flash the same version with the Forum Flashing tool without success.
Something else to try?
@Alan J T , can your patched bios version help?
I installed version 7D48VA9, removed the BIOS battery afterward, reset the BIOS, spat three times in the direction of New Taipei City, and sacrificed a goat. Just the usual stuff.
But after that, the sound came back.
I was then able to install the latest version using the Forum Flash Tool, and I still have sound.
Thank you for years of support to the community and getting the BIOS working again.
