msi h61mu-e35-b3 sata problem
greedyisgood
There are times that at system boot, my sata devices such as hdd and odd is not detected by the bios therefore it will not boot to windows then go directly to bios setup.
What I usually do is I connect the devices to other sata ports or tried to change sata cable but still it does not work. The fix I only see is to set to load optimized defaults in bios then boot the system repeatedly.
By the way all settings in the bios is always set to default. But what seems to be the problem?
