Just bought the Infinite RS gaming pc. Playing around with it my main concern had been cooling as I had found some iffy reviews after placing my order. So far doesn't seem to be an issue. Played AC Odyssey at 4k with nearly every option at ultra and both CPU and GPU stayed under 70 degrees. And it managed around 60 fps! I had planned on buying a 1440 monitor but snap I may go 4k. However....as far as I can tell...the rear fan is set to intake, and every other fan is exhaust. Obviously the top two fan and the top mounted radiator are set to exhaust, but I would think my front 2 fans should be flipped around as intake, and my rear fan flipped around to exhaust. Is this a common set up with more modern gaming pc's? Or was mine assembled by a...doofus?
