MSI K8T does NOT start!
Grunberg
SECOND LIEUTENANT
My MSI K8T mobo + AMD 64 3200+ combo do NOT start. Current configuration is as follows:
MSI K8T Neo motherboard
AMD Athlon 64 3200+ (with heat sink)
[Memory] PNY PC-2100 512MB DDR + PNY PC-2100 256MB DDR
[Tried two AGP video cards] NVidia GeForce 2 Pro 64MB + ATI Radeon 9600XT 128MB
[Tried two power supplies] Enlight 300W + Applied (?) 500W with I/O switch
Here are the symptoms and problem description. When I push Power:
1) The power supply fans and onboard fans run.
2) The floppy and CD-RW lights stay on. Can't Eject from CD-RW. Cables are correct.
3) The monitor's Power light blinks, nothing appears onscreen.
4) The video card does NOT run (nor does fan spin). Maybe not detected.
5) Hard drive doesn't seem to run. Jumper and cables are correct.
6) Front LED's do not light, but Reset LED stays lit when HD is connected
The bundled AMD heat sink/fan is attached to the CPU. The LED connectors are all intact. I tested this configuration with TWO different graphics cards and TWO different power supplies - STILL no boot!
This is extremely frustrating. I cannot continue to spend money on parts to try to fix the problem. Could it be the memory? Could it be a defective motherboard? (I've never had a defective motherboard).
Any help is much appreciated! Please send answers to grunburger@yahoo.com.
Thank you... :-)
Here some tips:
Connect your diagnostic led's and have a look in your manual to see what they mean, can be extremly helpful to troubleshoot.
Many graphic cards need an extra power connector, be sure its plugged in.
Your power supply 300W is too less, my 350w is just enough. 500w isn't 500w.
Try a good brand if you can like enemax, coba....
Clear your Cmos, and start witch sticking just one stick in the first memory slot.
Try another memory brand, Infineon DDR 400 CL 2,5/ Corsair XMS LL worked for me!
Floppy light is always lit when cable is connected wrong way, consider your manual.
Hope that helps
