MSI Katana 15 B12V - Randomly making boot sound
Hi all,
I'm having a problem with my MSI Katana as of today. At random intervals, the computer will make the sound it normally makes when switched on. It makes this sound whether it's turned on, off, sleep, unplugged from power, plugged from power, you get it.
I have not noticed any issues with the actual operation of the computer. Any ideas what could be causing it? Is it some kind of big hardware problem?
Thank you!
Is the cmos battery empty ? Check if the system date in bios is correct when your booting.
If it is not the case, try to use DDU tool to clean install audio-related drivers and software on the MSI website to check.
BTW, what changed did you make before having the problem?
