[What's the LED Player & the LED Theme Editor?]
The LED Player is a music player which allows the user to customize not only the color of the keyboard LED backlight but also the temple of the showing backlights.
By having a better control of the keyboard backlight settings, you can create various possibilities of the moving keyboard backlights. You can become the composer of your backlight keyboard and make your keyboard dance with the music in your own unique way.
*Give it a try and share with us what do you think about it!
[Download Link]
LED Player
[Note]
[Install the LED Player & the LED Theme Editor]
1. Extract the zip file.
2. Double click on the .exe file ?setup.exe? and follow the instructions to finish the installation.
[LED Theme Editor]
1. This shows you how the keyboard LED lights will be working based on your set up. (The keyboard is separated into three area.)
2. Add an image/icon picture of the customized LED theme.
3. Select the keyboard area where you want to set up. (Left/Middle/Right)
4. Select/Create/Load the LED Theme and change the settings.
5. Switch between ?Music? or ?Normal? mode. (Music mode presents when the music is playing and the normal mode presents when the music stops.)
6. Switch between ?Random? or ?In Order? which the color is being set. (Keyboard backlight will presents the color randomly from the setting column (8) with the setting ?Random? and ?In Order? on the other hand, will presents all set up colors in the exact order.)
7. To Add/Delete the color from the backlight color settings.
8. Backlight color setting panel.
- Order: Color order
- Energy Level (0-100): the brightness level of the backlight color.
- Delay (Sec): how long till the color light is shown.
- Color Setting: set the beginning color (left) and the finishing color (right).
- Period (Sec): how long till the next color is shown.
9. To apply the current LED theme and shows on the keyboard.
10. To apply the current settings and call out the LED Player.
11. To save the settings to the current profile or save as another theme profile.
12. Preview player shows the music track of the loaded music file.
13. Open the select music file, play and stop the playing music.
14. Adjusting the music volume.
[LED Player]
1. To import a LED theme profile.
2. List of the existing LED theme profiles.
3. To import the music files.
4. List of the imported music files.
5. Music player. (Previous, Play/Pause, Next)
6. Adjusting the music volume.
7. Shuffle/Repeat the music files from the music list.
[Download Link]
LED Player
[Note]
- This tool is only compatible for MSI notebook models.
GT72 Dominator Pro Dragon Edition/GT72 Dominator Dragon Edition/GT72 2QD Dominator/GT72 2QE Dominator Pro/GT72 2PE Dominator Pro/GT72 2PC Dominator
GE62 2QF Apache Pro/GE62 2QE Apache/GE62 2QD Apache/PE60 2QE/PE60 2QD
GE72 2QF Apache Pro/GE72 2QE Apache/GE72 2QD Apache/PE70 2QE/PE70 2QD
- Uninstall any keyboard backlight control managers (KLM and SSE) before installing the LED Player.
- The player supports music file format MP3/WAV.
[LED Theme Editor]
[LED Player]
