MSI Leopard GP66 11UG
berglake1
I have a a strange issue with the performance.
When i got my laptop and used CPU-Z benchmark it showed 5700Points, and now after 3 new BIOS and 3 months later it starts to show 5700 points and dropping fast to 5100 points in the same benchmark.
What is wrong?
My other Clevo 10875H show a steady score 5100 Points.
After bios update all settings was reset, so i had to enter advanced settings and enable GNA and other settings that was enabled with the first bios.
I think i have missed a setting in bios?
next3r
MAJOR
HWINFO + SENSOR
and run this bench - read CPU LIMIT REASON ??
berglake1
CPU LIMIT throttling at 95c.
In bios there is a setting you can choose when cpu will throttle and default is 95c, and next step is 103c.
next3r
MAJOR
this tab not control this :biggrin:
TCC offset or similar ,,.from Tmax "negative offset"
and not use 103C !!!
use better profile for cpu "max 90C" for performance :rolleyes:
edit
example ,..,TCC "6" from tmax-100C intel
94C prochot ?
but your setup is bad when run above 94C !!
berglake1
edit
94C prochot ?
Its default in bios, i have not changed anything with temperature.
