Which Windows version and build you use? [type 'winver' to check it]
Which BIOS version is now installed?
When you do shutdown, does the USB ports still have power or it's the issue is only for sleep?
Also list detailed system specs, see
>>Posting Guide<<
Yes i have issue with USB port only in sleep.When i shutdown pc no power in USB.
My system info:
Product Name: MAG B560 TORPEDO
OS: Windows 11 Pro 64 Ver.2009 (OS build 26200.8457)
BIOS Version: A.B2
BIOS Release Date: 03/26/2026
CPU: 11th Gen Intel(R) Core(TM) i7-11700F @ 2.50GHz
Memory: 32 GB @
- 8 GB DDR4-2666, Crucial Technology BL8G36C16U4R.M8FE1
- 8 GB DDR4-2666, Crucial Technology BL8G36C16U4W.M8FE1
Graphics: Virtual Desktop Monitor
Graphics: Meta Virtual Monitor
Graphics: RTX 4060 Ti GAMING 8G Series, 8188 MB
Drive: SSD, Samsung SSD 870 QVO 1TB, 931,51 GB
Drive: SSD, HP SSD S750 512GB, 476,94 GB
Drive: SSD, WDC WDS500G2B0A-00SM50, 465,76 GB
Drive: SSD, SanDisk SDSSDA240G, 223,57 GB
Drive: SSD, WD Blue SN570 1TB, 931,51 GB
Network: Xbox Wireless Adapter for Windows
Network: Intel(R) Ethernet Connection (10) I219-V
Network: Realtek PCIe 2.5GbE Family Controller
