Msi mag 240r
jamie1315a102e3
Unfortunately I've been hit with the famous aio fault.
Serial number isn't eligible, Not sure how long the warranty is. But its lasted alot long then 90% of the coolers. ( got it January last year )
pump is making a horrible noise. Temps are ridiculous, 75 degrees on bios.
Has anyone had any luck regarding a replacement? I've requested a ticket, and it's changed to proceed? So hopefully hear something soon
fauc
SECOND LIEUTENANT
Please provide picture for CPU temperature in BIOS setup as attachment around 5 minutes.
fauc
SECOND LIEUTENANT
This CPU temperature is around 76 drgree so it seem this cooling had some problem.
Please contact MSI for service directly.
jamie1315a102e3
They collected it, and is currently on the way to be "investigated ". I would imagine it has pump failure or the sediment problem! Will keep updating when I find out more, thanks.
badboy2k
if it was a non V2 version its probably got the sedement problem as there doing a Recall and replacement on them Units. you will probably get a V2 back in Exchange for it.
jamie1315a102e3
Yeah its a v1. Soon as I sent them the bios pic and the noise the pump made they issued a rma form. So fingers crossed I get the v2. Hopefully will hear from them this week
badboy2k
let us know what they send you.
jamie1315a102e3
Update.
Had a email saying I'll receive the new unit next week, haven't mentioned what they have done. Maybe they just repaired it? Or hopefully a v2 will be sent. What's the difference in them? Just the new fitting for the next gen Intel?
