steelsquirre158902d8
- Apr 28, 2026
Basically what the title is. I have an Asus QD-OLED here that has beautiful sRGB, but I wanted to get the HDR benefits of the MSI. I'm testing them both out since the Asus is still within the return window. I primarily game on a PS5 Pro, but plan to use it with my PC a bit as well.
When I set the MSI to sRGB, it does clamp the colors and desaturates the image as expected, but the gamma is messed up and causes the image to look more washed out than it should. The monitor is NOT in HDR mode, I've double-checked the OSD and also forced the PS5 HDR to be off at all times. The sRGB mode should be amazing with this monitor, so I'm stumped as to what's going on with it. I'm not sure if the HDMI 2.1 mode has anything to do with it and will check tomorrow, but there is an option to switch from "PC" to "Console" and I've had it on Console. This is the only way you can get a 4K downsampled image, but I'm wondering if that is causing some sort of bandwidth issue that's making the sRGB look like [***CENSORED***]... which doesn't make much sense since the Display P3 mode is vibrant as hell and the gamma curve seems correct.
Maybe I just got a bad unit or something or maybe I need to update firmware. But if anyone has come across this and had the same issue, please let me know if you fixed it!
