Hi MSI Support and community,
I’m having an HDMI compatibility issue between my MSI MAG 274UPF E2 and a PS5 Slim.
The PS5 displays “No Signal” when connected to the monitor. I have already tested the following:
I have also found other reports of similar PS5/PS5 Slim HDMI issues with MSI monitors, including reports where a firmware update resolved the problem on another MSI model.
I would therefore like to know:
Thank you.
- PS5 Slim is working normally.
- The original HDMI cable supplied with the PS5 works correctly with another monitor.
- I tested both HDMI ports on the MAG 274UPF E2, with the same result.
- The PS5 does not produce an image on either HDMI port of the MSI monitor.
- The same PS5 and HDMI cable work normally when connected to another display.
- What is the latest firmware version available for the MAG 274UPF E2?
- Is there a newer firmware version that is not publicly available on the MSI support/download page?
- Is there a firmware that addresses PS5 HDMI handshake or “No Signal” issues?
- If an update is available, how can I update the firmware on my MAG 274UPF E2?
- If there is currently no firmware fix, is MSI aware of this specific PS5 Slim compatibility issue?
Thank you.
