MSI MAG A750GF Power connectors
I'm new to building PC's and I have encountered a problem with cable connectors.
I've got 4 PCI-E cables, which 2 of them I want to use in connecting my GPU to PSU.
They have 8pin connector on one side and 6+2pin connector on the other side.
The problem is that every cable (there are 4 cables) has missing Pin on the side of 8pin connector. It looks like 2 wires are are connected to the Pin below.
Is it normal? If so, what connector should I insert into PSU and which into GPU?
Photos of those connectors:
The 6+2 is the gpu side and the other is psu. All is normal. They shouöd be marked as well.
