zwank153e02de
- Aug 13, 2024
Hello everyone,
I'm really in need of some help as I'm getting desperate with my new PC build. I have looked through other similar threads, but none of the solutions have worked for me. This is a brand new build, and I'm unable to get it to boot. I'm stuck and unsure what to do next, so any suggestions would be greatly appreciated. The system won't boot, and I'm seeing solid red and yellow LEDs lit up on the motherboard.
My configuration:
Motherboard: MSI MAG B650 TOMAHAWK WIFI
CPU: AMD Ryzen 9 7950X3D
RAM: Kingston Fury Beast 4 x 32GB, 5600 MHz, DDR5 DIMM
PSU: Seasonic Focus GX 1000W
(no graphic card installed)
What I have tried so far:
I'm really puzzled and don't know what else to try. Attaching some pictures also.
Any advice or suggestions would be highly appreciated so thanks in advance!
My configuration:
- - Attempted to start the system with only two RAM modules in slots 2 and 4 (counting from the left, next to the CPU) and also tried with just one module in slot 2.
- - Ensured that the DIMM modules were firmly seated by pushing them straight into the slot until the clips clicked into place.
- - Double-checked that the motherboard power connectors were correctly inserted.
- - Verified the CPU power connection: the motherboard has two 8-pin connectors, and I have four available on the PSU labeled as CPU/PCI-E. I plugged in the two CPU cables that came with the PSU and tried different combinations, but still no luck.
- - Inspected the CPU for bent pins several times. I was very careful when installing the CPU, ensuring it was placed vertically and aligned with the golden triangle marker in the top left corner. The pins look fine to me.
- - Disconnected non-essential case cables (e.g., audio and USB wires) and even removed the M.2 SSD to test if it made a difference (though I'm not sure if this was a useful step).
