MSI MAG B660M Mortar WIFI+i7 13700k - greatly overstated voltage and heat dissipation
sanctus
I can't use older bios which doesn't have 13Gen support officially.... So, wait for new version which was mentioned by Alan or just live with current settings. In real life usage I have TDP not more than ~180w and temerature lower than 80C.
265222951157c02df
This version supports the 13th generation and is the earliest bios
265222951157c02df
Ok, thx. May be I will try this so. But I'm not a big fan of idea being sticked to one outdated version of BIOS:(
Don't talk about loyalty with the brand, we are consumers, if you want to solve this problem you can only replace Z690.z790 now or wait for ThrottleStop to update 13th generation CPU support, or use my method.
Alan J T
Demon God
Like I said almost every time Venders find a bypass for doing it Intell roll out a bios update to block it venders be trying and intell keeps blocking
sanctus
ThrottleStop 9.5.1 works correctly on 13th Gen but it cannot be used to control the voltage if you have a B660 chipset. -info from developer. So, we have only few options at the moment - rollback to older bios or buy another one MB with Z chipset:(
sanctus
What the reason to block UV and try to reduce crazy 300w CPU consumption? There's no sense at all from my point of view....
265222951157c02df
That you would need to ask Intel
Asus Performance Enhancement 3.0 Maybe MSI will update something like that. Now the temperature of B660 is too high. I can't use the latest bios, because once I use the latest bios, the temperature will be 99° immediately. I'm using ND-D15, and the difference between water cooling and it is not much.
plutomate
MAJOR GENERAL
Is there any specific thread that is using offset on ASUS board without any performance penalty on latest BIOS? just wondering.
Alan J T
Demon God
So locking the CPU to a max of 90c will reduce temps by 10c and reduce performance Overall
Funny how limiting a CPU that is hitting 100c to 90c reduces Temp by 10c
Who'd have figured that would happen
Alan J T
Demon God
I know I don't use Intel much but can you not just set a limit in the BIOS of 90c
Kind of like AMD has in PBO settings
I'm pretty sure I have the option in BIOS of setting a Thermal target on the Intel devices I do have.
sanctus
BTW, does anybody know if MSI MAG Z690M Mortar WIFI has IA CEP disble functionality in BIOS? Almost ready to change my current MB and there's only 2 possible options at the market - MSI MAG B660M Mortar WIFI or ASUS ROG Strix Z690-G Gaming WiFi. I need mATX format, BT&Wi-Fi and optical SPDIF.
Alan J T
Demon God
Hi did some digging on Youtube and found a Video explaining but it is with an Engineering sample and not in English I think it is mandarin
SO results are not guaranteed but should be close to what you get with Retail CPU
the text will explain what CPU should work with Negative Offset with the Board you mentioned
So watch from the time stamp 11:50
Just set Translate to Auto in Setting and select your language
265222951157c02df
I watched the latest video posted by handsome man Lin, I have sold my B660 and bought 690. I want my CPU to work more consistently because I need to render for a long time
Alan J T
Demon God
Having this Info up front and provided by Intel sure would make life easier, But I grabbed some screenshots but not sure if I can post without Permission as it is Internal MSI stuff.
So at least I will be able to check what will work now with a negative Offset.
sanctus
If I can ask which MB do you have now? Does it have IA CEP disabling functionality or it works good even without this?
Thanks a lot for this video - really very informative
