MSI MAG coreliquid 240R not showing in mystic light
Well, did you connect it to a JRAINBOW header?
onefastatv
Mine shows up in DC exactly like yours, until the new DC software upgrade now it only shows the MB no duel fan or dram.
fatedust
FIRST LIEUTENANT
You should connect it to JRAINBOW headers on your motherboard.
After that, go to Mystic Light and select MB > click on the drop down list and select JRAINBOW to control the RGB lighting.
