MSI MAG CORELIQUID C240
kenji128e02a9
hello, i buy this AIO because the pump was advertised as 4200tpm but it does not exceed 4055tpm.
Why do you make false announcements and descriptions... This is false advertising.
You should add in your descriptions 4200rpm with +/- 10% . As this is not added it is considered to go up to 4200rpm!
badboy2k
that RPM is a -3.45% reduction what is your PSU's +12V Power line outputting (According to ATX 2.3, spec of your PSU, the specs for +12V are between +11.40 V to +12.60 V (there Spec Of a PSU is +/- 5% and that is suppluing power to your Pump so what is its voltage))?
badboy2k
idle 12v / maxi 12.096v / average 12.079v
ok that voltage looks good. then yeah its under performing on its RPM by 3.45% its not a +/- 10% its closer to most other Spinning components that have a tolerance of +/- 5%. i have a Corsair fan that should spin at 2000RPM but never gets over 1943RPM (lower by 2.85%).
kenji128e02a9
@darkhawk I open a ticket and now I can no longer connect to my MSI account only on the forum...
"Your MSI account or ip address has been locked as we've detected suspicious activity.
It seems that someone tried to use your account for fraudulent purposes.
We typically suspend accounts for violations of Terms of Condition."
What the hell?
kenji128e02a9
It doesn't matter they lost a customer definitively. if they don't like a customer making a suggestion, I would buy elsewhere it's not the brands that are missing (Asus forever)
