I cannot use dragon center at the moment , as I do not have the motherboard installed , I am saving for Ryzen 9 3900X , I am also inputting the number off the sticker on the side of the box .@heydon_c
Try to install Dragon Center, which should auto detect your motherboard.
Utility > MSI Dragon Center
https://www.msi.com/Motherboard/support/MAG-X570-TOMAHAWK-WIFI.html#down-driver&Win10 64
Why are you not using the sticker on the side of your motherboard box? Also, try using your phone to take a picture of the sticker so you can zoom in. Otherwise, until you can get a better picture or read it off the box, not much we can do to help. Registration worked fine for my Tomahawk.
Thats the problem I am using the sticker on side of box to register , it won't recognise itWhy are you not using the sticker on the side of your motherboard box? Also, try using your phone to take a picture of the sticker so you can zoom in. Otherwise, until you can get a better picture or read it off the box, not much we can do to help. Registration worked fine for my Tomahawk.
