So you're saying, anything above the default profile of DDR5-4800 is making games almost unplayable?
Can you check with LatencyMon if it shows high system latencies at higher RAM speeds?
https://www.resplendence.com/latencymon
For some reason my powerplan was on balances instead of performance.
It made the msg disappear but tested in my game and fps still jumps around from 140 to 50fps on default 6000Mhz
_________________________________________________________________________________________________________
CONCLUSION (full default 4800Mhz)
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:02:02 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DUKE-GAMING2
OS version: Windows 11, 10.0, version 2009, build: 26100 (x64)
Hardware: MS-7E12, Micro-Star International Co., Ltd.
BIOS: 1.K7
CPU: AuthenticAMD AMD Ryzen 9 7950X 16-Core Processor
Logical processors: 32
Processor groups: 1
Processor group size: 32
RAM: 31849 MB total
CPU SPEED
Reported CPU speed (WMI): 4501 MHz
Reported CPU speed (registry): 450 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 141,70
Average measured interrupt to process latency (µs): 12,154167
Highest measured interrupt to DPC latency (µs): 127,40
Average measured interrupt to DPC latency (µs): 2,772539
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 44,550
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0,000184
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0,000353
ISR count (execution time <250 µs): 11808
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 1147,440
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 591.74 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,003261
Driver with highest DPC total execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%) 0,012476
DPC count (execution time <250 µs): 51898
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 25
DPC count (execution time 1000-2000 µs): 2
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: systemsettings.exe
Total number of hard pagefaults 2708
Hard pagefault count of hardest hit process: 1456
Number of processes hit: 13
PER CPU DATA
CPU 0 Interrupt cycle time (s): 1,851819
CPU 0 ISR highest execution time (µs): 4,640
CPU 0 ISR total execution time (s): 0,006498
CPU 0 ISR count: 10879
CPU 0 DPC highest execution time (µs): 1147,440
CPU 0 DPC total execution time (s): 0,385607
CPU 0 DPC count: 35057
CPU 1 Interrupt cycle time (s): 0,923884
CPU 1 ISR highest execution time (µs): 44,550
CPU 1 ISR total execution time (s): 0,007294
CPU 1 ISR count: 929
CPU 1 DPC highest execution time (µs): 808,640
CPU 1 DPC total execution time (s): 0,023578
CPU 1 DPC count: 3508
CPU 2 Interrupt cycle time (s): 1,154163
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 451,470
CPU 2 DPC total execution time (s): 0,049662
CPU 2 DPC count: 7479
CPU 3 Interrupt cycle time (s): 0,732132
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 252,30
CPU 3 DPC total execution time (s): 0,005396
CPU 3 DPC count: 1404
CPU 4 Interrupt cycle time (s): 0,401003
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 27,830
CPU 4 DPC total execution time (s): 0,000629
CPU 4 DPC count: 183
CPU 5 Interrupt cycle time (s): 0,441140
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 227,360
CPU 5 DPC total execution time (s): 0,002144
CPU 5 DPC count: 237
CPU 6 Interrupt cycle time (s): 0,286227
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 20,970
CPU 6 DPC total execution time (s): 0,000944
CPU 6 DPC count: 382
CPU 7 Interrupt cycle time (s): 0,326983
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 38,10
CPU 7 DPC total execution time (s): 0,000651
CPU 7 DPC count: 50
CPU 8 Interrupt cycle time (s): 0,202531
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 25,810
CPU 8 DPC total execution time (s): 0,000615
CPU 8 DPC count: 217
CPU 9 Interrupt cycle time (s): 0,198533
CPU 9 ISR highest execution time (µs): 0,0
CPU 9 ISR total execution time (s): 0,0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 33,980
CPU 9 DPC total execution time (s): 0,000301
CPU 9 DPC count: 74
CPU 10 Interrupt cycle time (s): 0,677967
CPU 10 ISR highest execution time (µs): 0,0
CPU 10 ISR total execution time (s): 0,0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 188,890
CPU 10 DPC total execution time (s): 0,004360
CPU 10 DPC count: 965
CPU 11 Interrupt cycle time (s): 0,713328
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 208,510
CPU 11 DPC total execution time (s): 0,004124
CPU 11 DPC count: 923
CPU 12 Interrupt cycle time (s): 0,141370
CPU 12 ISR highest execution time (µs): 0,0
CPU 12 ISR total execution time (s): 0,0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 11,50
CPU 12 DPC total execution time (s): 0,000032
CPU 12 DPC count: 9
CPU 13 Interrupt cycle time (s): 0,131112
CPU 13 ISR highest execution time (µs): 0,0
CPU 13 ISR total execution time (s): 0,0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 0,0
CPU 13 DPC total execution time (s): 0,0
CPU 13 DPC count: 0
CPU 14 Interrupt cycle time (s): 0,151674
CPU 14 ISR highest execution time (µs): 0,0
CPU 14 ISR total execution time (s): 0,0
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 9,620
CPU 14 DPC total execution time (s): 0,000070
CPU 14 DPC count: 24
CPU 15 Interrupt cycle time (s): 0,141199
CPU 15 ISR highest execution time (µs): 0,0
CPU 15 ISR total execution time (s): 0,0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 7,610
CPU 15 DPC total execution time (s): 0,000071
CPU 15 DPC count: 24
CPU 16 Interrupt cycle time (s): 0,100084
CPU 16 ISR highest execution time (µs): 0,0
CPU 16 ISR total execution time (s): 0,0
CPU 16 ISR count: 0
CPU 16 DPC highest execution time (µs): 24,880
CPU 16 DPC total execution time (s): 0,000206
CPU 16 DPC count: 51
CPU 17 Interrupt cycle time (s): 0,093887
CPU 17 ISR highest execution time (µs): 0,0
CPU 17 ISR total execution time (s): 0,0
CPU 17 ISR count: 0
CPU 17 DPC highest execution time (µs): 21,440
CPU 17 DPC total execution time (s): 0,000176
CPU 17 DPC count: 28
CPU 18 Interrupt cycle time (s): 0,111198
CPU 18 ISR highest execution time (µs): 0,0
CPU 18 ISR total execution time (s): 0,0
CPU 18 ISR count: 0
CPU 18 DPC highest execution time (µs): 0,0
CPU 18 DPC total execution time (s): 0,0
CPU 18 DPC count: 0
CPU 19 Interrupt cycle time (s): 0,08870
CPU 19 ISR highest execution time (µs): 0,0
CPU 19 ISR total execution time (s): 0,0
CPU 19 ISR count: 0
CPU 19 DPC highest execution time (µs): 0,0
CPU 19 DPC total execution time (s): 0,0
CPU 19 DPC count: 0
CPU 20 Interrupt cycle time (s): 0,145891
CPU 20 ISR highest execution time (µs): 0,0
CPU 20 ISR total execution time (s): 0,0
CPU 20 ISR count: 0
CPU 20 DPC highest execution time (µs): 56,320
CPU 20 DPC total execution time (s): 0,004859
CPU 20 DPC count: 620
CPU 21 Interrupt cycle time (s): 0,188569
CPU 21 ISR highest execution time (µs): 0,0
CPU 21 ISR total execution time (s): 0,0
CPU 21 ISR count: 0
CPU 21 DPC highest execution time (µs): 37,080
CPU 21 DPC total execution time (s): 0,003748
CPU 21 DPC count: 636
CPU 22 Interrupt cycle time (s): 0,118772
CPU 22 ISR highest execution time (µs): 0,0
CPU 22 ISR total execution time (s): 0,0
CPU 22 ISR count: 0
CPU 22 DPC highest execution time (µs): 13,40
CPU 22 DPC total execution time (s): 0,000048
CPU 22 DPC count: 5
CPU 23 Interrupt cycle time (s): 0,103644
CPU 23 ISR highest execution time (µs): 0,0
CPU 23 ISR total execution time (s): 0,0
CPU 23 ISR count: 0
CPU 23 DPC highest execution time (µs): 33,370
CPU 23 DPC total execution time (s): 0,000321
CPU 23 DPC count: 36
CPU 24 Interrupt cycle time (s): 0,099577
CPU 24 ISR highest execution time (µs): 0,0
CPU 24 ISR total execution time (s): 0,0
CPU 24 ISR count: 0
CPU 24 DPC highest execution time (µs): 4,190
CPU 24 DPC total execution time (s): 0,000008
CPU 24 DPC count: 2
CPU 25 Interrupt cycle time (s): 0,085292
CPU 25 ISR highest execution time (µs): 0,0
CPU 25 ISR total execution time (s): 0,0
CPU 25 ISR count: 0
CPU 25 DPC highest execution time (µs): 0,0
CPU 25 DPC total execution time (s): 0,0
CPU 25 DPC count: 0
CPU 26 Interrupt cycle time (s): 0,117752
CPU 26 ISR highest execution time (µs): 0,0
CPU 26 ISR total execution time (s): 0,0
CPU 26 ISR count: 0
CPU 26 DPC highest execution time (µs): 0,0
CPU 26 DPC total execution time (s): 0,0
CPU 26 DPC count: 0
CPU 27 Interrupt cycle time (s): 0,114792
CPU 27 ISR highest execution time (µs): 0,0
CPU 27 ISR total execution time (s): 0,0
CPU 27 ISR count: 0
CPU 27 DPC highest execution time (µs): 0,0
CPU 27 DPC total execution time (s): 0,0
CPU 27 DPC count: 0
CPU 28 Interrupt cycle time (s): 0,103936
CPU 28 ISR highest execution time (µs): 0,0
CPU 28 ISR total execution time (s): 0,0
CPU 28 ISR count: 0
CPU 28 DPC highest execution time (µs): 26,250
CPU 28 DPC total execution time (s): 0,000080
CPU 28 DPC count: 11
CPU 29 Interrupt cycle time (s): 0,084613
CPU 29 ISR highest execution time (µs): 0,0
CPU 29 ISR total execution time (s): 0,0
CPU 29 ISR count: 0
CPU 29 DPC highest execution time (µs): 0,0
CPU 29 DPC total execution time (s): 0,0
CPU 29 DPC count: 0
CPU 30 Interrupt cycle time (s): 0,108212
CPU 30 ISR highest execution time (µs): 0,0
CPU 30 ISR total execution time (s): 0,0
CPU 30 ISR count: 0
CPU 30 DPC highest execution time (µs): 0,0
CPU 30 DPC total execution time (s): 0,0
CPU 30 DPC count: 0
CPU 31 Interrupt cycle time (s): 0,086539
CPU 31 ISR highest execution time (µs): 0,0
CPU 31 ISR total execution time (s): 0,0
CPU 31 ISR count: 0
CPU 31 DPC highest execution time (µs): 0,0
CPU 31 DPC total execution time (s): 0,0
CPU 31 DPC count: 0
CONCLUSION (DEFAULT 6000Mhz No profiles)
LatencyMon has been analyzing your system for 0:05:13 (h:mm:ss) on all processors.
SYSTEM INFORMATION
BIOS: 1.K7
Processor groups: 1
RAM: 31849 MB total
CPU SPEED
Highest measured interrupt to process latency (µs): 947,30
Average measured interrupt to process latency (µs): 18,234710
Highest measured interrupt to DPC latency (µs): 940,0
Average measured interrupt to DPC latency (µs): 8,448712
REPORTED ISRs
Highest ISR routine execution time (µs): 133,10
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0,000318
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0,000618
ISR count (execution time <250 µs): 47012
REPORTED DPCs
Highest DPC routine execution time (µs): 1212,690
Highest reported total DPC routine time (%): 0,022371
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0,060811
DPC count (execution time <250 µs): 511575
DPC count (execution time 500-10000 µs): 35
DPC count (execution time 1000-2000 µs): 18
Process with highest pagefault count: msmpeng.exe
Total number of hard pagefaults 3544
Hard pagefault count of hardest hit process: 1762
Number of processes hit: 34
PER CPU DATA
CPU 0 Interrupt cycle time (s): 21,945480
CPU 0 ISR highest execution time (µs): 133,10
CPU 0 ISR total execution time (s): 0,031727
CPU 0 ISR count: 43284
CPU 0 DPC highest execution time (µs): 1212,690
CPU 0 DPC total execution time (s): 5,792435
CPU 0 DPC count: 457094
CPU 1 Interrupt cycle time (s): 4,862052
CPU 1 ISR highest execution time (µs): 45,460
CPU 1 ISR total execution time (s): 0,030257
CPU 1 ISR count: 3728
CPU 1 DPC highest execution time (µs): 108,070
CPU 1 DPC total execution time (s): 0,059850
CPU 1 DPC count: 10527
CPU 2 Interrupt cycle time (s): 5,089044
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 349,810
CPU 2 DPC total execution time (s): 0,113058
CPU 2 DPC count: 17307
CPU 3 Interrupt cycle time (s): 3,712829
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 63,170
CPU 3 DPC total execution time (s): 0,016651
CPU 3 DPC count: 4729
CPU 4 Interrupt cycle time (s): 4,543771
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 69,60
CPU 4 DPC total execution time (s): 0,006730
CPU 4 DPC count: 1919
CPU 5 Interrupt cycle time (s): 4,519675
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 57,950
CPU 5 DPC total execution time (s): 0,005803
CPU 5 DPC count: 1591
CPU 6 Interrupt cycle time (s): 3,919328
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 41,0
CPU 6 DPC total execution time (s): 0,0040
CPU 6 DPC count: 1260
CPU 7 Interrupt cycle time (s): 3,958527
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 47,260
CPU 7 DPC total execution time (s): 0,002630
CPU 7 DPC count: 655
CPU 8 Interrupt cycle time (s): 4,082943
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 61,50
CPU 8 DPC total execution time (s): 0,004715
CPU 8 DPC count: 1164
CPU 9 Interrupt cycle time (s): 4,162316
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 76,440
CPU 9 DPC total execution time (s): 0,003515
CPU 9 DPC count: 870
CPU 10 Interrupt cycle time (s): 4,668953
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 435,930
CPU 10 DPC total execution time (s): 0,026042
CPU 10 DPC count: 3959
CPU 11 Interrupt cycle time (s): 4,376101
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 77,520
CPU 11 DPC total execution time (s): 0,021109
CPU 11 DPC count: 4253
CPU 12 Interrupt cycle time (s): 2,967699
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 34,380
CPU 12 DPC total execution time (s): 0,001085
CPU 12 DPC count: 320
CPU 13 Interrupt cycle time (s): 3,034263
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 90,850
CPU 13 DPC total execution time (s): 0,003463
CPU 13 DPC count: 241
CPU 14 Interrupt cycle time (s): 3,471461
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 39,870
CPU 14 DPC total execution time (s): 0,001436
CPU 14 DPC count: 409
CPU 15 Interrupt cycle time (s): 3,534254
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 75,130
CPU 15 DPC total execution time (s): 0,001473
CPU 15 DPC count: 353
CPU 16 Interrupt cycle time (s): 0,834594
CPU 16 ISR count: 0
CPU 16 DPC highest execution time (µs): 30,180
CPU 16 DPC total execution time (s): 0,000276
CPU 16 DPC count: 54
CPU 17 Interrupt cycle time (s): 0,837257
CPU 17 ISR count: 0
CPU 17 DPC highest execution time (µs): 28,390
CPU 17 DPC total execution time (s): 0,000344
CPU 17 DPC count: 77
CPU 18 Interrupt cycle time (s): 1,018604
CPU 18 ISR count: 0
CPU 18 DPC highest execution time (µs): 34,660
CPU 18 DPC total execution time (s): 0,001056
CPU 18 DPC count: 193
CPU 19 Interrupt cycle time (s): 0,993322
CPU 19 ISR count: 0
CPU 19 DPC highest execution time (µs): 44,170
CPU 19 DPC total execution time (s): 0,000396
CPU 19 DPC count: 77
CPU 20 Interrupt cycle time (s): 1,280672
CPU 20 ISR count: 0
CPU 20 DPC highest execution time (µs): 76,260
CPU 20 DPC total execution time (s): 0,008876
CPU 20 DPC count: 1586
CPU 21 Interrupt cycle time (s): 1,362143
CPU 21 ISR count: 0
CPU 21 DPC highest execution time (µs): 88,620
CPU 21 DPC total execution time (s): 0,013093
CPU 21 DPC count: 1432
CPU 22 Interrupt cycle time (s): 1,238734
CPU 22 ISR count: 0
CPU 22 DPC highest execution time (µs): 38,940
CPU 22 DPC total execution time (s): 0,000618
CPU 22 DPC count: 112
CPU 23 Interrupt cycle time (s): 1,159975
CPU 23 ISR count: 0
CPU 23 DPC highest execution time (µs): 50,640
CPU 23 DPC total execution time (s): 0,000955
CPU 23 DPC count: 171
CPU 24 Interrupt cycle time (s): 0,712509
CPU 24 ISR count: 0
CPU 24 DPC highest execution time (µs): 41,650
CPU 24 DPC total execution time (s): 0,000951
CPU 24 DPC count: 154
CPU 25 Interrupt cycle time (s): 0,701618
CPU 25 ISR count: 0
CPU 25 DPC highest execution time (µs): 35,30
CPU 25 DPC total execution time (s): 0,000644
CPU 25 DPC count: 136
CPU 26 Interrupt cycle time (s): 1,685659
CPU 26 ISR count: 0
CPU 26 DPC highest execution time (µs): 63,350
CPU 26 DPC total execution time (s): 0,001667
CPU 26 DPC count: 317
CPU 27 Interrupt cycle time (s): 1,893774
CPU 27 ISR count: 0
CPU 27 DPC highest execution time (µs): 47,890
CPU 27 DPC total execution time (s): 0,000991
CPU 27 DPC count: 183
CPU 28 Interrupt cycle time (s): 1,479465
CPU 28 ISR count: 0
CPU 28 DPC highest execution time (µs): 74,810
CPU 28 DPC total execution time (s): 0,001956
CPU 28 DPC count: 90
CPU 29 Interrupt cycle time (s): 1,684154
CPU 29 ISR count: 0
CPU 29 DPC highest execution time (µs): 66,550
CPU 29 DPC total execution time (s): 0,001723
CPU 29 DPC count: 113
CPU 30 Interrupt cycle time (s): 1,066110
CPU 30 ISR count: 0
CPU 30 DPC highest execution time (µs): 39,790
CPU 30 DPC total execution time (s): 0,001262
CPU 30 DPC count: 186
CPU 31 Interrupt cycle time (s): 1,087081
CPU 31 ISR count: 0
CPU 31 DPC highest execution time (µs): 55,620
CPU 31 DPC total execution time (s): 0,000801
CPU 31 DPC count: 96
