MSI MAG Z790 TOMAHAWK MAX WIFI
iliyanml914e802d7
I recently build a PC with MSI MAG Z790 TOMAHAWK MAX WIFI Motherboard.
When I install windows 10 I was not having internet.
I install LAN driver and everyting is ok right now, (connected with Ethernet cabel)
but my question is how can I connect to internet with motherboard wi-fi without cabel, is there any driver, cuz I search on official web site and didn't find one for this Motherboard (Wi-fi driver or something).
Any solution to this problem?
Hi everybody:
I had the same issue, even installing the included USB drivers, the updated ones, and nothing. :(
Here the explanation:
First of all: Wifi 7 Only works on Windows 11.
When I was installing Windows 11, system didn't detect Wifi or Ethernet connexion. I had to do the "oobe\bypassnro" step . Once installed the MB drivers, Ethernet deviced was recogniced, but not the Wifi one.
I re-installed again and again W11, I tried with W10, and nothing. I founded this MB have Intel BE 200 BT & Wifi7 chip, so you can Find here the drivers. BUT, even that, I had to Clear CMOS first: Unplug the power cable, push Clear CMOS button for 10 Sec, plug again and Power ON. Then, I re-installed (repair) That BE200 drivers and Voilá.
NOTE: Make sure you have enabled BT&WIFI connection on your BIOS
I hope this solution works for you.
Cheers!
