I have it because there is a very useful free mini toolbar I use to monitor my specs in realtime (I closed the program when tried install MSI Center):
PC Case: FRACTAL Meshify 2 RGB
The Meshify 2 RGB is a high-performance case with a bold, stealth-inspired aesthetic.
www.fractal-design.com
Main Board:
MSI MAG Z790 TOMAHAWK WIFI, ATX, Socket LGA 1700, Dual Channel DDR5 7200+(OC)MHz,
2x PCIe x16 slots, 4x M.2 slots, 1x HDMI, 1x DP, 4x USB 3.2 Gen2, 4x USB 3.2 Gen2,
4x USB 2.0, Type-C, 7.1 HD Audio, 2.5Gbps LAN
Bios Version: E7D91IMS.H20 (12/29/2022)
Video Card/GPU, brand and exact model:
Gigabyte RTX 4090 Gaming OC 24GB GDDR6X
PSU, brand and model:
be quiet! DARK POWER PRO 12 1200W, 80 PLUS Titanium efficiency (up to 94.7%), Full mesh PSU front, CM
CPU:
13th Gen Intel(R) Core(TM) i9-13900K 3.00 GHz
Memory stick(s), brand and model:
Kingston DRAM 64GB 6000MT/s DDR5 CL36 DIMM (Kit of 2) FURY Beast RGB EXPO
SSD/ HDD, brand and model:
- KINGSTON FURY Renegade 2TB SSD with Heatsink, M.2 2280, PCIe 4.0 NVMe, Read/Write 7300/7000MB/s, Random Read/Write: 1000K/1000K IOPS,
- ADATA SU630 480GB
- SEAGATE HDD Desktop Barracuda Guardian (3.5"/1TB/SATA 6Gb/s/rmp 7200)
- SEAGATE HDD Desktop Barracuda Guardian (3.5"/2TB/SATA 6Gb/s/rmp 7200)
CPU COOLER:
MSI MPG CORELIQUID K360 V2 RGB
Keyboard:
RAZER PRO TYPE ULTRA
RAZER GOLIATHUS EXTENDED CHROMA MERCURY EDITION
Mouse: LOGITECH MX MASTER 3
Any Additional PCIe cards installed into your system?: No
OC: No
Operating System WINDOWS 11 PRO
Display:
(1) Gaming LED VA Philips 42.5", Quantum Dot, 4K UHD, HDR 1000, FreeSync, Display Port, Черен, 436M6VBPAB
Is it a TV?: No
How display is connected to the GPU?: Display Port
(2) DELL P2419H
Is it a TV?: No
How display is connected to the GPU?: HDMI
RGBs:
- FRACTAL Meshify 2 RGB (4x RGB FANs)
- MSI MPG CORELIQUID K360 V2 RGB (3x RGB FANs)
- Kingston DRAM 64GB 6000MT/s DDR5 CL36 DIMM (Kit of 2) FURY Beast RGB EXPO
- Gigabyte RTX 4090 Gaming OC 24GB GDDR6X
