muratozsertta158202e4
- Aug 26, 2024
My system is as follows;
MSİ MAG Z790 TOMAHAWK WİFİ
İNTEL İ5 13400 F
GSKİLL 16X2 trident z5 7200 mhz cl34
ZOTAC RTX 4070 SUPER
MSI MAG CORELIQUID 360R V2
KINGSTON 512 GB nvme ssd
SEASONIC 650watt 80+ bronz powersupply
ASUS GT502 PLUS CASE
My computer starts normally, however. While testing, the rams are defined as 7200 mhz from the xmp setting and when I change the settings to xmp mode, it gives a BSOD. When I manually set it to 7000 mhz, there is no problem. However, I want to use my rams at full capacity. By the way, the latest version of the bios is installed. Can you help me with this?
İNTEL İ5 13400 F
