MSI MAG274R2
ugafarov202156a02e1
Hi. I have got MSI MAG274R2 monitor. I can not find how to change the Refresh rate, the OSD menu says it is on 85Hz. The monitor is capable of 165Hz. I want to set it to 165hz. How do I do that?
fauc
SECOND LIEUTENANT
Change your display refresh rate in Windows
For 165Hz, please install extra NVIDIA or AMD graphic card on desktop system.
For NVIDIA, please install GTX 10xx or latest.
For AMD, please install RX500 or latest.
Don't connected it on laptop if you want to 144Hz or latest.
ugafarov202156a02e1
I have installed Asus Tuf Gaming NVIDIA GTX 1660 super. I tried to changed refresh rate from advanced display settings but it shows max 85hz.
badboy2k
It is a pc. I am using DP to connect it.
are you using the Cable the Monitor came with? (I am assuming your connecting it to the GTX 1660 Supers Displayport)
also are you setting the resolution from the Nvidia Control Panel?
badboy2k
Yes. You right about all
ok out of curiosity as i am suspecting that the Cable it came with is defective and you connect it with a different cable EG the HDMI Cable to see what that one does and report back with the result? (to me its acting like the cable is not a DP 1.4a Cable like it should be but a DP 1.1 Cable)
