MSI MEG CORELIQUID S360 Image output problem
igru.kok12cd02ad
I have a problem, I recently assembled a PC, and water cooling is not displayed in the msi center
MSI MEG CORELIQUID S360 Image output problem.
robitroc159e02e5
Same here with the S280. "coreliquid" option disapeared under features i assume after the 1.0.45.0 update. It was there just a few days ago.
robitroc159e02e5
still having issues or has it been fixed? i just bought one and im kinda scared now lol
No it hasnt worked since may (it worked for a few weeks at first) i wanted to wait for a few msi center updates just in case but i finally sent in a ticket today. I can see the default pattern but there is no option for coreliquid under features anymore. Otherwise it works perfect but yeah, pretty annoying.
Alan J T
Check Firmware version if you can believe it is FW 0005 for Coreliquid S360 is you firmware up to date for the AIO CPU cooler.
Alan J T
It is updated, thanks though.
Humm ok so can you swap your connector to another USB 2.0 header if you have a SPARE
See if it makes a difference
And in Bios can you enable Wake by USB and or disable the ERP
robitroc159e02e5
I tried all this and nothing sadly.
robitroc159e02e5
Hum could all ways try a previous version not sure if it will help though
I remember the numbers being "stuck" (temperature wasn't going up or down) i restarted the pc and if i remember right that's right around when this started. I completely forgot about that till right now. >_< sorry.
Guess i'll rma it when i get the chance. Thanks for the help anyway
