cakmak.se15bc02eb
- Mar 4, 2024
Hi, couple of days ago i finished my build and everything was working allright. But today i've noticed something weird.
My system:
CPU: i9 -13900k
MOBO: MSI MPG Z790 Carbon Wifi
AIO: MSI MEG Coreliquid s360
Case: MSI MEG Prospect 700r
i've built this system so i can render images. but my aio radiator fans are stuck between 740-760 rpm and the temperature shown on the aio is stuck at 37 degrees celsius
even when my MOBO shows 95-99 degrees (led debug), aio screen still shows 37-40 degrees and my case fans and my aio radiator fans are pretty quiet.
i've tried to change the sync mode to MOBO from the case screen but then still my radiator fans are pretty quiet even though my case fans are spinning much more faster. (but their rpm are stuck even with no load)
probably an error related to msi center. i used sync mode to msi center and adjusted the fan curves. but still aio radiator fans are stuck at 740-760 rpm even though my cpu is burning.
what should i do? thanks in advance...
My system:
CPU: i9 -13900k
