MSI MEG CORELIQUID S360 PROBLEM
cakmak.se15bc02eb
Hi, couple of days ago i finished my build and everything was working allright. But today i've noticed something weird.
My system:
CPU: i9 -13900k
MOBO: MSI MPG Z790 Carbon Wifi
AIO: MSI MEG Coreliquid s360
Case: MSI MEG Prospect 700r
i've built this system so i can render images. but my aio radiator fans are stuck between 740-760 rpm and the temperature shown on the aio is stuck at 37 degrees celsius
even when my MOBO shows 95-99 degrees (led debug), aio screen still shows 37-40 degrees and my case fans and my aio radiator fans are pretty quiet.
i've tried to change the sync mode to MOBO from the case screen but then still my radiator fans are pretty quiet even though my case fans are spinning much more faster. (but their rpm are stuck even with no load)
probably an error related to msi center. i used sync mode to msi center and adjusted the fan curves. but still aio radiator fans are stuck at 740-760 rpm even though my cpu is burning.
what should i do? thanks in advance...
I recently bought a coreliquid s360 and I also have these freezes with version 2.0.36.0
So is anybody working on this problem or should I buy another AIO from a more competent manufacturer ?
Just for info what I tried and what will not work during the freeze:
Unplugging sata and usb connection, watercooler is restarting, however problem persists.
Stopping and restarting msi services in windows - no effect.
It is obvious the application does no longer have communication to the cooler and stats like cpu temperature. RYZEN MASTER will get the correct CPU temperatures all the time.
Depending on load this is really dangerous for the CPU, because there will be no longer a dynamic speed adjustment of the fans.
Update: I started RMA process for refunding, I think there will be no solution in the near future, design is nice, but functionality of this AIO is really bad.
you are right , refunding it , at this price , you have more chose, Don't cause trouble for yourself.
mine s360 has those promble too and very funny this S360 AIO have a cooling radiator with NZXT logo.
but TW MSI wanna me Sign an agreement that there are no issues with this item
i cant belive , how they called this is nothing wrong haha
S360 with NZXT radiator
Hello.
I just wanted to leave some feedback on the S360 AIO from MSI.
I think the AIO is fine and solid, however the software is a complete different story.
First off, the CPU is a 14900k, and thus the AIO has to be working perfectly well otherwise we all know that this CPU is going to burn itself out.
There are versions where the CPU temp readout will be 0C/Core Clock speed 0Mhz. Because MSI things the temp is 0C, it will not ramp up the radiator fans/pump/etc during heavy gaming load, and thus CPU will thermal throttle eventually.
The latest version has WMI Provider issue, where it seems to be creating constant impact on this service by MSI, causing 4-5% CPU usage, and running CPU Cores at all core speeds. You can find more info here, its been a few months, and we have no fix from MSI
The only option to sort of get a working version is to use 2.0.32.0 version. This version doesn't have issues with WMI Provider, however it does have other issues.
Issue 1 - CPU/Core Clock speed 0Mhz randomly. This results in CPU overheating, and also damaging the CPU.​
Issue 2 - All RPM readouts on the Fan settings tab is 0​
Then, the most annoying issue, is the auto update. Every time i reboot my PC, i randomly notice WMI Provider issue is back, and ofcourse MSI has auto updated.
This auto update is so frustrating, because the latest version is constantly profiling WMI Provider Service, causing high CPU usage and forcing All Core clock run speed.
I've blocked it from firewall - Still Updates
I've told the App to not update - Still Updates
On reboot of PC, when i start MSI Center, it asks do you want to update, i say skip don't remind me. It Updates.
The last few months have been an absolutely pain in the behind dealing with this AIO. I think physically the AIO is good, however the software is a complete disappointment. MSI is yet to update this issue, i've seen plenty of reddit threads, even here as well about the WMI issue, but nothing is resolved.
As i am running a 14900k i cannot under any circumstance have the AIO fail out on me and cause damaged to my CPU. There is no way MSI will even take remote blame if the CPU Fails and probably blame user error.
Solution for me was, as i saw no updates from MSI, throw the thing in the trash, and went to a Artic Freezer III AIO. Yes no LCD, but i don't care, i can finally get rid of all the crap MSI Services run as well. I still don't know what MSI Voice Control is, clearly it has nothing to do with an AIO but it's still there as a service sitting in the background.
On top of that, every god dam time it reinstall, it resets the setting around sharing data with MSI. Default setting should ALWAYS be Opt out. This should be something the user has to opt in.
Anyway...that's my rant, avoiding all MSI products for future, MSI Center has got to be the worse software i have dealt with, and used.
Just wanted to update. Packed up the S360 away, i checked one more time that night before buying and the stupid app updated, and started triggering the wmi issue along with 0C.
On the AFIII 420mm, soooooooo much better, i have an option to control pump/vrm and fans with one or individual, no need for 3rd party software, i just jump on the bios, setup the fan curve, and thats it. Its running great.
I sold the S360 cheap to a friend, who i explained the issue but he was happy to deal with it.
Imagine using a 13900 or 14900 CPU and have the AIO decide to crap out and you notice temps are 90C while gaming.
I have a CORELIQUID S360, same problem since 2022!
MSI doesn't care as long as the product is sold!
It's always pleasant to smell burning and see the water circuit above 85 degrees.
Please boycott this brand, which has become as cheap as Aliexpress (Taobao for the locals).
Sell your MSI equipment; they have become incompetent at designing!
Don't hesitate to give their products a bad rating and make noise about it!
我有一个CORELIQUID S360,自2022年以来就一直有同样的问题!
只要产品卖出去,MSI根本不在乎!
闻到烧焦味并看到水冷管路超过85度,总是让人"愉快"。
请大家抵制这个品牌,它已经变得和阿里巴巴一样廉价(对本地人来说是淘宝)。
卖掉你的MSI设备吧,他们已经变得无法设计出合格的产品了!
不要犹豫,给他们的产品打低分,并到处传播这个消息!
Hi all
Another one to the list.
MSI center 2.0.41.0
Coreliquid 3.0.0.71
Cooler assistant 1.0.0.01
Coreliquid and cooler assistant software fight for the cooler and fans controls.
Unprecedented. Two plugins of the same Hub, does not know each other.
It is funny that Corsair iCUE does, coming from third party manufacturer.
yes hello
on the topic
MSI MEG Prospect 700r case
MSI MEG 1300W I PSU 3.0 PCIE5
MSI MEG B550 UNIFY
MSI MEG S CORE LIQUID 360
MSI 3090TI SUPRIM X
4x16gb 4000mhz gskill Royal
Ryzen 5950x
fck MSI center
all updates fresh including win10 nvidia blabla
System rebuilt, after 2 hours overheating error when switching back on, everything disassembled, checked, reassembled, works, next evening when switching on overheating error again.
screws on pump head slightly loosened, works, after 30 minutes overheating error
new bios, overheating error when switching back on.
it runs well from time to time but not brilliantly and all the values look good.
I suspect the MSI Center is to blame, especially since it's rubbish anyway as ARGB isn't displayed as well as in the Dragon Center and the functions are far too extensive and clash with BIOS settings.
with an €88 Arctic Freezer 2 or 3 it runs great and the fully integrated MSI MEG S CORE LIQUID for €300 is a load of rubbish.
if anyone has a tip, please let me know
yeap, as like manual.
Bios AMI BIOS7D89v1B3(Beta version)2024-02-22
MSI Center MSI Center_2.0.32.0
CoreLiquid 3.0.0.63
This problem extends to the operating system, even when you just go into the BIOS, that is, the pump does not start when turned on pc.
Hi, did you find a silution to this issue? I've bought S360 last week and it behaves the same... It is random but usually after a full PC restart there is such problem. After 2-3 restart the pump starts normally and it runs fine. The issue does not occur when I hibarnate PC so it looks like some software/driver issue. Especially when sometimes during the restart or shutdown and restart the LCD shows CPU, FUN and PUMP parameters and sometimes it's just the fancy graphic displayes and the parameters are shown afrer MSI Center starts up. This is so frustrating. I'm scared of restarting my PC...
MSI Center software is the biggest crap this company can create. My computer crashes at random times. It is impossible to work on it. For the price of this cooler, everything should be tweaked to perfection. If MSI can't do software right, they better not get involved at all. The company stopped developing some 20 years ago. I do not recommend any components from this manufacturer. They have not been able to deal with the CPU thread locking bug for so long. I have just lost a few hours of my work because my computer decided that it would crash at such a time and damage my files that I have been working on for several months. Keep it up MSI. You are just losing customers. I am totally screwed by the whole situation with your cooling already.
My s360 been working fine for the last couple of months, but recently it got updated (i dont know why you would update something that works) and now again it locks at a spesific temperature and ignores cpu temperature. so this is the last time i am writing this:
NO ONE CARES ABOUT YOUR AI CRAP, NO ONE USES YOUR SO CALLED MSI CENTER ADDONS HOW CAN YOU GUYS EXPECT US TO DOWNLOAD YOUR (PROBABLY ANOTHER TRASH) AI FEATURE WHILE YOU ARE INCAPABLE OF FIXING ONE SMALL ISSUE???? I GUESS WE ALL HAVE TO BOYCOT THIS TRASH COMPANY SO THEY FIX THEIR SOFTWARE.
I AM TELLING YOU GUYS AGAIN AND AGAIN: NO ONE, NOT A SOUL ON EARTH USES YOUR BULLSHT AI FEATURES. STOP DEVELOPING THEM AND FOCUS ON FIXING THE SOFTWARE. I AM TIRED OF TRYING TO FIX "YOUR" PROBLEM EVERYTIME YOU UPDATE THE SOFTWARE. WHAT ARE YOU GUYS UPDATING?????
PPL WITH ACTIVE GUARANTEES IN THIS TOPIC PLEASE LISTEN TO ME AND SEND IT BACK. IT'S EXPENSIVE AND IT DOESN'T WORK... THEY DO NOT CARE AND THEY DONT KNOW HOW TO FIX IT. PEOPLE WORKING ON THIS SOFTWARE ARE .............
I am writting this just after powered on the PC. I needed to shut it down because the CPU temperature stucks AGAIN at 37º C, and when I noticed the water temperature was at 80º Centigrades.
Please, hire good developers, remove the useless AI stuff and make a good software that can manage your own hardware. Yesterday I updated the coreliquid version to 3.0.0.74 and today emerge the issues again. The never ending history.
Just forced update MSI center from MS Store, and a coreliquied new version appears, 3.0.0.75, and now surprise! the CPU temperature is moving. Definitely, you are developing this software with the feet.
Same problem with my system (newly built a few weeks ago), even with actual latest MSI SW:
CPU: AMD 9800x3d
MOBO: MSI MPG x870e Carbon Wifi
I have to reboot 2 or 3 times until temperature works after login.
Temperature always stucks after a second parallel user login in windows.
Temperatures also always stucks after logout and login again with same user.
Looking into the log-Files, it seems that CC_engine cannot be started due to "driver load fails" issue.
CPU: AMD 9800x3d
could you share the zipped file generated by this MSI tool? you can upload it to a cloud drive if the file's too big to attach here
https://download.msi.com/uti_exe/nb/MSI-Collect-Log-Tool.zip
Do you have MSI Center installed in both Windows users? Are both Windows users administrator accounts? Can you see the problem logging in right after logging out?
Generated file is attached.
MSI Center was installed only in Administrator account.
Mostly the other (non-admin) account is logged in.
From some research, I read that corsair iCUE may be problematic together with MSI Center, but iCUE is required on the PC (for special gaming controller).
So I disabled iCUE in Windows Start-Apps. Within iCUE, I disabled the watching parameters regarding CPU.
  • Report_20250103095401.zip
After looking into these log-files I found that one problem arises from "ResumeFromSuspend" (-> Mutex WaitForSingleObject : 258) which is always the case if "windows fast startup" is enabled (enabled by default after windows 11 installation).
After disabling "windows fast startup", it seems that after every reboot the coreliquid service works properly.
However, I'm sure this will not solve the problem in case of a second user login or if a user logs off and on again.
This is a high priority bug in MSI SW which can destroy the CPU if not fixed.
Also interesting are the exceptions in Log of MSI-Center#Liberator:
[Exception] GetAllIconFolderData
: System.ArgumentException: Path may contain an empty string or just a space
bei System.IO.Directory.CreateDirectory(String path)
bei UC_Liberator.FolderFileData.GetAllIconFolderData()
Also interesting. In case of reproducable temperature stuck (log off and on again), I always get following windows error if I restart or log off again:
