HamiltonRL
- May 1, 2020
Hello everyone!
I currently have an MSI MEG X570 ACE motherboard paired with an AMD Ryzen 9 3900X, and I'm considering upgrading my GPU to an Radeon AI PRO R9700 Creator 32GB.
My main goal is to use this system as a personal workstation for AI development, machine learning, and local AI model inference.
Before purchasing the GPU, I'd like to confirm a few technical details:
If anyone from MSI or someone with experience using newer professional AMD GPUs on the X570 platform could provide some guidance, I would really appreciate it.
Thanks in advance!
- GPU compatibility: Is the Radeon AI PRO R9700 fully compatible with the MSI MEG X570 ACE and Ryzen 9 3900X?
- PCIe compatibility: Since the R9700 uses PCIe 5.0 x16 and my motherboard supports PCIe 4.0, should the card work normally at PCIe 4.0 x16, without any compatibility issues?
- BIOS requirements: Is there a specific BIOS version required or recommended for this GPU? Are there any relevant settings, such as Above 4G Decoding, Resizable BAR, or UEFI/CSM, that I should configure?
- Future multi-GPU setup: I'm also considering installing a second R9700 in the future for AI workloads using AMD ROCm. Would the motherboard support both GPUs operating at PCIe 4.0 x8/x8 with my Ryzen 9 3900X?
- Known limitations: Are there any known compatibility issues, hardware limitations, or stability concerns with this combination?
Thanks in advance!
