Make sure to install drivers-only, not the whole Intel package, and use Device Manager to install. It consists of only 4 files. The latest driver version from
Station Drivers is 1.1.3.28, dated 03/05/2022, but driver file version date can be later. The files are:
- e2f.cat
- e2f.inf
- e2f.sys
- e2fmsg.dll
Make sure to install the mentioned Windows 10 drivers (1.1.3.28) even on Windows 11. Windows 11 is tricky. It comes with some generic buggy drivers for many network adapters that are part of Windows 11 "Features" component needed for network adapters to work specifically for Windows 11 installation as an attempt to enforce creation of non-local Microsoft cloud-based account during Windows 11 setup. That process can be bypassed, but that's off-topic. If you uninstall those generic buggy drivers from Windows 11 "Features", then official Intel Windows 11 drivers can't even be detected as compatible by Windows 11 Device Manager, but Windows 10 1.1.3.28 drivers work fine. I suggest either sticking to the latest version of Windows 10 or disabling Windows 11 network adapter "Features" with DISM commands or a tool like NTLite before performing Windows 11 installation.
I also suggest trying the following optimized settings (that can be changed in Windows Device Manager for Intel I226-V) to reduce latency, packet loss, increase throughput, and improve privacy at the cost of some CPU power:
- ARP Offload - Disabled
- DMA Coalescing - Disabled
- Enable PME - Disabled
- Energy Efficient Ethernet - Disabled
- Flow Control - Disabled
- Interrupt Moderation - Disabled
- Interrupt Moderation Rate - Off
- IPv4 Checksum Offload - Enabled
- Large Send Offload V2 (IPv4) - Disabled
- Large Send Offload V2 (IPv6) - Disabled
- Log Link State Event - Disabled
- NS Offload - Disabled
- Packet Priority & VLAN - Disabled
- Receive Buffers - 2048
- Selected Suspend - Disabled
- Select Susepnd Idle Timeout - 5
- Speed & Duplex - use whichever one fits your router Ethernet port speed, try to not use Auto-Negotiation
- TCP Checksum Offload IPv4 - Rx & Tx Enabled
- TCP Checksum Offload IPv6 - Rx & Tx Enabled
- Transmit Buffers - 2048
- UDP Checksum Offload IPv4 - Rx & Tx Enabled
- UDP Checksum Offload IPv6 - Rx & Tx Enabled
- Wait for Link - Off
- Wake from S0ix on Magic Packet - Disabled
- Wake on Link Settings - Disabled
- Wake on Magic Packet - Disabled
- Wake on Pattern Match - Disabled
- Untick/disable "Allow the computer to turn off this device to save power" in Power Management tab
Download
TCP Optimizer and use the settings I provide in attached screenshots (but adjust MTU based on what your ISP offers).
