MSI Monitor Not Displaying MacBook (Works Elsewhere, Black Screen at Home)
Subject: MSI Monitor Not Displaying MacBook (Works Elsewhere, Black Screen at Home)
Hi everyone,
I’m running into a really confusing issue with an MSI monitor and hoping someone here has seen something similar.
Setup:
  • MSI monitor (recent purchase, still under warranty)
  • MacBook Pro (Apple silicon, latest macOS)
  • Connecting via USB-C → HDMI cable
  • Monitor only has HDMI input (no USB-C)
The issue​
The monitor powers on and detects an HDMI signal, but the screen stays completely black.
What’s strange is that everything does work under certain conditions:
  • The monitor works perfectly when connected to other computers (tested at the store with both Windows and Mac)
  • My MacBook works perfectly with a TV (no issues)
  • My phone connects to the monitor via USB-C and displays fine
  • I even had it working once at home briefly
But now, at home:
  • The monitor detects HDMI input
  • Occasionally flickers when changing resolution
  • But never actually displays an image
What I’ve already tried​
  • Multiple HDMI cables (including ones provided/tested at the store)
  • Different USB-C ports on my MacBook
  • Different wall outlets (multiple rooms)
  • Full power cycles (monitor + Mac)
  • Changing resolutions and refresh rates in macOS
  • “Show all resolutions” and testing lower resolutions (e.g. 1080p, 720p)
  • Restarting macOS display system
  • Clamshell mode (closing laptop to force external display)
  • Disconnecting/reconnecting in different sequences
Key observations​
  • Monitor clearly receives a signal (does not say “No Signal”)
  • Screen stays black despite signal detection
  • Same exact setup works in-store but not at home
  • Phone → monitor works reliably
  • Mac → TV works reliably
Question​
Has anyone experienced a similar issue where:
  • A MacBook works with a monitor in one environment but not another?
  • The monitor detects signal but shows a black screen?
Could this be:
  • A compatibility issue between macOS and this monitor model?
  • Something related to signal format (RGB vs YCbCr, etc.)?
  • A firmware issue on the monitor?
Any ideas or things I haven’t tried would be really appreciated.
Thanks in advance 🙏
