MSI MPG 271QRX QD-OLED Question.
FuFuriju
Hi there,
I have a question about the Service menu.
I updated the Monitor from 009 to 015. Used the standart settings from 009, or at least I didnt changed anything because everything was fine except this white lines. Since that 015 update the color, Brightness and "Image Quality" is less. It now looks more blurry and it has kinda ghosting in fast paced games. This wasnt the case before the update.
Additional I have higher reaction times/input latency in HDR mode or lets say the timings when I need to press a Key for exmaple on the Keyboard is much sooner. for Rythmgames this is a killer. It feels like it has a delay of 25-30ms in HDR mode and makes fast paced games kinda unplayble for me now.
Tried many things but nothing helped tbh. Was very happy with the Monitor with 009. Now I wanted to try to fix it maybe through the service Menu, or at least check if everything is fine.
My questions are, because I only saw the Service Menu through screenshots/Images and dont want to make some mistake:
Screenshot I found online is attached.
1. Will the warranty void if using/open the service Menu?
2. What if possible can I change in there for color and/or brightness.
3. What can I check to make sure everything is fine with the monitor?
4. What are the different options for? like CRC Auto, Dummy, Product, Panel NPC and so on?
5. is the Service Menu Reset option the same like the normal OSD reset? Or does it reset even more or different things?
Thanks for helping in advance! :)
Sincerly
FuFu
