tanvirrahman36161602f4
- Mar 7, 2026
I've had this monitor for 1 month now. I updated to the latest firmware as soon as I received it. Till now I was absolutely in love with this monitor. But today when I turned off my PC, the monitor started causing issues. If I am on a dark page and then go to a bright white page, the screen stays dark and takes a few seconds to increase the brightness, And sometimes the LED just stops working a few LED in the middle will be bright and the rest of the LED will be dim, The third picture shows the brightness issue. The same thing happens in gaming as well. The local dimming system is totally messed up for some reason.
And haloing. It started haloing really badly after 10–12 minutes of use. When I power off the monitor and power it on again, it works normally. Then after about 10 minutes it starts haloing again. I have added a second picture of the normal haloing. One of the things I loved about this monitor is that the haloing wasn't noticeable enough to bother me. But it suddenly started haloing really badly. My halo dimming is still at 100. I have added a second photo of normal haloing as a reference.
A couple of troubleshooting steps I did:
- 1. Reset monitor settings.
- 2. Changed local dimming settings to level 3–1 to see if it still causes issues (it does).
- 3. Turned down and up the halo dimming (no change whatsoever. The halo dimming is not working).
- 4. Reinstalled the firmware, but still nothing.
- 5. Deleted the Windows HDR profile and tried Auto HDR. Still the same.
- 6. Turned off Auto HDR and only kept HDR on. Still the same issue.
1st picture : Bad Haloing.
2nd picture : What normal Haloing looks like on this monitor.
3rd picture : Brightness and Led issue.
