MSI MPG A1000G PCIE5 not working?
davidcorle15b602e5
I recently purchased a new MPG A1000G PCIE5 for my desktop to use with my 4090 FE. After removing my old supply, I dropped in the MPG and started setting it up.
The mobo, cpu, sata, gpu and pcie supplies were connected but when I tried to turn on the PC, nothing happened. The switch on the PSU itself was set to on, and the zero fan button was _not_ engaged.
I started disconnecting my components one-by-one until only the Mobo power was connected, but still nothing. The fan in the PSU never moved.
At this stage I disconnected the PSU from the mobo, and used a paperclip in the PS-ON and one of the Ground pins in the Mobo connector. I can hear the PSU click, but the fan never comes on. This is the same behaviour with the zero fan button engaged or disengaged.
I put the old power supply back in and the PC booted normally, so I know the other components are fine.
At this stage I believe my new PSU is dead-on-arrival.
However, I just wanted to confirm that with newer MSI power supplies, connecting the PS-ON pin to a ground pin should spin up the fan?
darkhawk
I would agree that your PSU is probably dead on arrival.
bowpro39
Just finished a build for a buddy of mine using same PSU with a 4090 MSI Suprim Liquid and MSI X670 Carbon. The only indication I get there is power is the Smart Button and CMOS Button on the IO panel on the back of the MB light up but nothing else happens. I thought I was going crazy, tried reseating cables, checking the case wires, tried different power cables, different wall outlets, all nothing. Very disappointed!
teletubby_po
To infinity and beyond.
FIRST LIEUTENANT
Same here, the unit I bought is a dead piece of brick.
Tried different cables, power outlets and nothing is working.
:confused:
Take a look at this link, Its started by the same person who started this post here but it seems like alot of people are having the same issue.
😑 https://www.reddit.com/r/MSI_Gaming/comments/10k94ov
hi, do you have another PSU that works on your system?
is it just the fan not spinning, or you can't boot up the system at all?
nghi_aqu156302d7
So apparently what happened was, I used the old 24 pin (14+10Pin to 24 Pin ATX) from the previous power unit (Cougar GEX 850) as I thought they're all the same.
When I changed the 24 pin cable to the one that came with MSI A1000G, power came through and Everything's working now.
Hallelujah 🙌 praise the lord...
I think the GEX 850 cable isn't compatible with A1000G despite looking very identical 🤔
teletubby_po
FIRST LIEUTENANT
thx for the update! great to hear that it working now 🙌
