MSI MPG B850 Edge wifi - 7E62v1A61 bios AGESA PI-1.3.0.1b - storahci event id 129
EasterEEL
CORPORAL
Since installing this new bios, the event viewer is throwing three storahci 129 errors in quick succession (10 secs apart), Reset to device, \Device\RaidPort0, was issued, when returning from standby. I tried a different SATA port which makes no difference. The bios is set to AHCI not raid for SATA.
I rolled back to the 1.2.0.3g AGESA PI 1.2.0.3g updated bios and that error does not occur. CrystalDiskInfo is not reporting any issues with my Crucial MX500 1TB SATA SSD (used as a backup drive), so I think it's spurious message related to the new bios, as no other issues. AI suggests the storage controller (ASMedia) wakes up too slowly compared to the rest of the system causing Windows 11 to forcibly reset the connection. So can I safely ignore?
Sound like you don't experience any issue from normal usage right now, well, hard to say if it can be ignored or not especially if someone is using RAID configuration?
Have you tried to bench the drive with crystaldiskmark? Also, do you only have one SSD (SATA) connected? Because your profile says otherwise (with Kingston Nvme SSD).
Main drive is Kingston nvme, the Crucial SATA is used for various backup, including Acronis full backup of the Windows 11 partition. CrystalDiskMark benchmark results are as expected for an SSD drive.
No issues with hard disks other than the three storahci 129 errors (10 secs apart) every time system returns from standby, (which started with the AGESA PI-1.3.0.1b bios).
Further feedback. The issue was resolved by downloading and installing the Asmedia SATA Driver 3.3.5.0000 2025-07-16, which is there on the drivers & downloads support page. The only description is: Fix HWiNFO stuck on “Detecting ATA/SCSI Drivers” process when being launched.
AI gave loads of suggestions including bios settings, windows settings none of which worked. Clearly something changed with the latest AGESA bios, which the dedicated Asmedia SATA Driver is able to fix, even though it is not a new driver (circa 2020/22, not aware there is a newer version).
This thread, gives some insight as to the probable reason the Asmedia drivers fix the problem:
https://forum-en.msi.com/index.php?...-wifi-hard-drive-spindown-timer-issue.415414/
So the options with the latest AGESA bios, is accept the storahci event id 129 errors returning from sleep with the Microsoft generic SATA drivers, (probably spurious), or use the Asmedia SATA Driver not allowing hard disk power saving. At least, this is true with the Crucial MX500 SSD, I'm using.
