MSI MPG GUNGNIR 110R Case RGB Controller
david.j.mor155002db
Good morning experts!
I have figured out most of the cables within the case, including the SATA cable coming from the RGB controller that will plug into the same from the PSU (which I have not received yet). With that SATA cable coming from the RGB controller board is another cable that looks like a connection that would go to the mobo.
My motherboard is: MSI MPG Z690 Force WiFi and I'm not sure where this cable/connector should plug into the mobo. I was going to settle on plugging it into JRAINBOW1 but thought I would confirm that here. The user manual nor the website for the case, does not identify or call out the cable even exists coming from the RGB controller? 🤔
Anyone care to take a stab at this one?
David
teletubby_po
To infinity and beyond.
FIRST LIEUTENANT
yess, connect the ARGB connector from the RGB controller to the board's jrainbow header.
