TheK9
- Jan 18, 2022
For the longest time I have been doing stability tests using OCCT, and recently I noticed that stress testing my CPU, i9-12900k with XMP enabled on my 64GB ddr4 4x16GB kit it was spitting out hardware core errors. I figured out that disabling XMP resolved the issues. And after more digging, I discovered people have had a similar issue with the same board and CPU core errors with XMP. Someone suggested downgrading the bios in another forum post, so I did so, and low and behold it fixed the errors in OCCT, and the random program crashing. The version I downgraded to was 7D31v11. Through hours of testing, it seems ONLY this bios version allows me to run XMP at the rated speeds without program/game crashing, and hardware issues in OCCT. Is this a known issue? Is this being looked into? Are there any solutions besides sticking to this old bios version? This happens regardless of a CPU overclock of any kind, and XMP being the only factor.
Infomation about system:
CPU: i9-12900k
Motherboard: MSI MPG Z690 EDGE WIFI DDR4
Bios version pre downgrade: 7D31v14
Bios versions tried: 7D31v14, 7D31v13 , 7D31v12 , 7D31v11
Ram model: G.Skill Trident Z NEO Series 64GB (4 x 16GB) 288-Pin SDRAM (PC4-28800) DDR4 3600 CL16-19-19-39 1.35V Quad Channel Desktop Memory Model F4-3600C16Q-64G
CPU: i9-12900k
