MSI MYSTIC LIGHT NOT RECOGNIZING MOTHERBOARD RGB HEADERS
Same here after update 2 days ago motherboard not detected in Mystic Light. Hardware monitoring in Msi center works.
Mystic Lighting 3.16.4
Msi Center 2.0.47.00
MSI MPG Z790 CARBON WIFI (MS-7D89)
BIOS-datum: 09/26/2024
BIOS-versie: 1.E0
Can change colors with openRGB so the problem is Mystic lights.
The same thing, mystic light was updated today, the fans stopped being visible, before that everything worked ok
The problems with the backlight have also started. After updating to version 3.0.16.4, I stopped seeing the backlight of the motherboard (MPG X670E CARBON WI-FI), as well as the backlight of the processor's water cooling. It only sees the backlight of the MSI RX 7900 XTX graphics card. MSI doesn't seem to be testing its updates...
Same issue as everyone else. Typically buggy MSI Center. Mystic light can now only see my MSI graphics card and not the MB aRGB
Have updated Bios (MS-7D25 to A.K0) and LED FW Update(7D25 to 05). Have completely removed and re-installed MSI Center and updated to latest version.
MB: PRO Z690-A WIFI
Will wait for the inevitable patch.
Only ram for me too. I used to have motherboard, JRainbow 1 & 2 etc on here and was working fine before mystic light update. Does anyone know how to roll back a mystic light update?
MSI Center v2.0.45.0
Mystic light: v3.0.16.4
Model: MPG Z690 Carbon Wifi
I'm experiencing the same problem where only RAM modules are displayed. However, it works fine with SignalRGB, indicating that the issue lies with Mystic Light. Using SignalRGB, I can control all the RGB lighting for the motherboard, fans, RAM, and other components.
same here, only RAM option available, created support ticket for this issue
The odd thing is, my version was working fine unless they updated the software in the last day. This also raises questions about whether they test their software between updates, because if they had run it after updating, the issues would have been clear.
Hello yesterday I plugged my rgb fans into the jrainbow1 header and everything worked fine but today after I started my pc my fans started flashing white light and MSI MYSTIC LIGHT wasnt detecting the headers on my motherboard and the motherboard as whole
Same Issue here, installed a m.2 frokm my old ssd. and after installing msi center, mystic lights only detected ram but nor my fans, spended over two hours even going through bios and nothing, god bles this thread because i would still be investiganting the error.
Ill join the club
Mystic Lighting 3.0.16.4
MSI Center 2.0.48.0
PRO B650-VC WIFI
LED FW Update(7D78)
Mystic Light is not working in my version of Dragon Center after I uninstall MSI Center to verify if Motherboard is seen..... and its not
Dragon Center Dragon Center_2.0.149.0.exe
***UPDATE***
For Win 11
1. I ran MSCONFIG, disabled ALL non Window Apps; rebooted
2. Went to BIOS disabled RGB Light; saved
3. When logging into Windows, Do not let anything "RGB Related" load via permission prompts
4. Start MSI Center, as ADMIN, should get message about exiting MSI Center and restarting. Then, per the previous System Message, you should get a prompt to Click Yes from the User Access Control (Win 11, there is a slide, no YES NO prompt). FYI you cant start or install MSI CENTER as msconfig has everything turned OFF. "I started MSI and got the UAC message 3 times, wanted to be sure I wasnt missing anything"
5. Reboot PC
6. Go BIOS re enable RGB Light, save BIOS. You will be prompted "nothing has been changed to save" each time you turn on or off the RGB Lights when saving. SAVE ANYWAYS
7. Log into Windows, re enable all your MSCONFIGs that you disabled.
8. Reboot
9. After loading into Windows and all has loaded. Enter MSI Center, you should now see the motherboard
Now I can see the MOBO, however since I pushed the LED button on the chasis. I dont know how to reset the LED properly. I Hold 3 - 5 seconds the RGB Lights Cycle White then they turn off. I click LED again. The lights come back on but they are not responding to music, which ive set for the MOBO in Mystic Light. So now im stuck, with RGB Lights that wont cycle to music
I am using ICUE / Steelseries / Razer / MSI Apps Ive made this work. Gimme a bit Ill figure out why the RGB are nonresponsive Ill update.
Lastly.... MSI Center stopped recognizing my REGISTERED Items. Its having a heck of time recognizing ive registered my MOBO already look:
my version was working fine before update too
