MSI P67A-C45 (B3) Newb needs Help with connections..
Ben_Cartwright
Hi all..
First time posting here, but have been in the shadows for quite a while..  ;-))
Anyway, i decided to finally take the plunge, and build my own PC, and now i'm beginning to hit a few bumps.
I have a couple of questions that i would like some help with, if possible to reassure myself i may be in the right direction..
I bought THIS PSU and was hoping someone could tell me where the Blue connectors (one labelled CP and one labelled U1) Connect to?
Is it into JPWR2? And does it/do they only connect in the correct way? (Do i remove the plastic cap and attach both? :bonk: :bonk:
and i bought THIS VIDEO/GRAPHICS CARD and i'm guessing the RED "PCI express" and "SLI ready" connect to that somehow (Haven't opened box yet for card)
Again, wondering is there a certain way for them to connect.
Also, from my chassis, the "AC '97" and "HDA" connectors go to JAUD (I guess), does it matter which one? (I currently have "HDA" connected)
I have i5 2500k already on board. (If that makes a difference).
Yes, you plug the blue connectors into the JPWR2. They can only be connected one way. Remove the cap and insert the additional 4-pin connector since your PSU has it.
Your graphics card requires both PCI-E 6-pin connectors be connected. Again, they can only be connected one way. One of your PCI-E connectors is 6+2 pin so you can leave the additional 2-pins dangling when you plug the 6-pin connector in.
Thanks a million Mark for your reply..  :hat tip:
Do the Audio plugs go into JAUD? and does it matter which one?
Also, last question.. (i hope)  :hypocrite:
Any recommendations for testing it all, before i plug it in, and press the power?
Should i (Can i) test individual parts first?
Thanks again.
Yep, connect the front panel audio to the JAUD. If you need the pin layout, it says in the manual. I would say the HDA connector is the one to connect.
Thanks again.
Check all power connections, seating of the RAM and add-on cards, check the HSF is plugged into the fan header, and obvious things like that.
As for testing, enter the BIOS and make sure the CPU isn't running too hot. Set up the RAM with the required timings and voltage, and test with >>Memtest86<< for several hours. No point starting the Windows installation if say your RAM has errors, since it will corrupt files during the install, if it installs at all.
Again, Thanks for replying, with advice  :biggthumbsup: i wouldn't even have thought about..  :(
I have a fair bit ahead of me then..  :)
I was just going to connect everything, and hope for the best....  :bonk:
I haven't a clue to set up the RAM.. I'll fire ahead with everything else for now anyway..
I hope to God i don't run away with myself (something i tend to do when i'm a bit excited) Just got to calm myself, and take it easy..  ;D
Just recheck and confirm everything, i think is best, and when in doubt..  :idea: ASK!  :idea:
Thanks a mill Mark, You have no idea how comforting a bit of advice from someone that knows what they are doing, can be.  :smile:
Primary blue dimm slot 'only' for initial startup. I hope you got RAM that has DDR3 1333 SPD profiles on it. :-))
Added: After successful bootup, load OS & system drivers, then shut down & add the other RAM Stick(s). Before adding the other RAM however, it also may be best to update the BIOS to the very latest version, but that may not be necessary if everything is running smoothly.
Do initial setup on MB with parts not installed in the case, sheet of plain brown card board is good or wood tabletop.
Hi...
Thanks everyone for replying..  :angel: :)
I connected the monitor i got with it, and it's go no power at all..  :nooo:
I connected to my TV via HDMI, and the screen says.. 9.. 3.. then just a dot (i think)
Then winki appears, asking start with installation, or full winki..
I can see some of the MSI control thing, but it's too big for the screen. Then it reboots, finds no media, and then back to winki.
I did something stupid (i think).. After that, i tried to boot with Ubuntu 10:10 live CD.. it got to a point where it said, "No OS to boot from" or something like that. I'll check tomorrow exactly what it says. But, then i reinserted the MSI software, and when i go to winki (Either choice - start install, or full) It stays on the Winki white page with logo for about five minutes, and then i get the ubuntu error again.. and am asked to clear all users within 3 seconds, by pressing F8.
If this makes any difference, here is the spec for the PC.
Except the monitor.. I bought this one HERE
