MSI P67A-GD55: Where do i plug-in the HD Audio connector (Front panel Audio)?
blizzaro
PRIVATE FIRST CLASS
Yes, I've tried reading both my Motherboard and Chassis manuals, but none of them isn't help.  It's a HAF 912 Advanced chassis.  I did however found the AC97 header, can i plug in the HD Audio to a AC97 header?  Since the HD Audio plug is daisy chained off the end of AC97.
:think: You can't plug the AC97 connector in the HD header. The pc case's HD connector should fit correctly.
Hard to figure out what you imply, there is no AC'97 audio header on the MB, it's Realtek? ALC892 HD audio. If the case has front panel HD audio then you don't have any problem.
I've tried  plugging in both AC97 and HD Audio onto that connector but still, no headphone/audio were detected.
