- Oct 22, 2009
First off my spec's.
I7 920 (just normal clock and voltage 1.160).
OCZ 6 gig (3x2gig) 8-8-8-24 1.65v Gold DDR3 1600.
Dual 260 gtx's 55nm Msi.
Windows 7 64 bit
Corsair 850watt psu
Bios version 3.6
Now my problem: I can't get the motherboard to run the memory at 8-8-8-24 with 1.65v. My system becomes very unstable and crashes!! Even if I leave the timings at "auto" and push voltage to 1.65 v it crashes. I would Like to say that this boards bios settings are shi*. It doesnt show current value!! What mobo does that? Anywayz I looked at OC center to see what my mem voltage was at on auto. It told me 1.8v!! at 1600!! Funny thing is sytem is stable at that setting!! I ran prime 95 for over an hour!! When I try to bump the voltage to where suppose to be (1.65) it goes ape shi* and restarts every two seconds. I ran all 3 sticks in mem test through ms-dos and all 3 sticks are ok (no errors). I'm out of options soo 1.8V i know is WAYYYY to high and i dont wanna damage the sticks so i back them down to their stock settings (1066 1.5v) and they run dead stable at that. Also what the heck is with stupid message in Bios telling me 1.65v may damage the cpu!
almost all DDR3 1600 mem is 1.6v+, I highly doubt they would make a memory at that voltage if it was going to damage your CPU. Ironically the 1.65 voltage setting is not in "red" but "high performance" setting in the bios.
My tries:
I have tried setting CPU voltage to stock setting away from auto -- no change
I have tried setting memory timings and voltage in bios --- no change
I have tried lower memory voltage to 1.6v since guys OCZ said can run at that also --- no change
I have ran memtest on all 3 sticks in dos mode --- All ok
I have tried bumping QPI voltage up by .090 -- No change
I have tried setting the PLL voltage to 1.8v --- No change
I have tried running sticks at 1066 (since all they are is oc'd 1066) at the rated timings andd 1.5 volts --- Dead stable
My only other option is a new mobo and i really dont wanna spend the $$ on it since saving for a 5870. Sooo PLZ if know anything might help post it up and ill give it a shot!!! But i am not running sticks at 1066 when I paid for 1600 and the board says it supports that!!
Windows 7 64 bit
Corsair 850watt psu
Bios version 3.6
My tries:
