MSI Prestige 14 AI Evo C2HMG-093IN – Loose Touchpad Feel, Tapping Sound and Chassis Flex
lokeshjmy
Thread title: MSI Prestige 14 AI Evo – Loose Touchpad Feel and Chassis Tapping Sounds
Hi everyone,
I recently purchased an MSI Prestige 14 AI Evo C2HMG-093IN and noticed the following issues:
  • The touchpad feels flimsy and produces a noticeable tapping sound/sensation.
  • Pressing the chassis to the left of the touchpad makes the touchpad-related symptoms disappear; this area also feels loose.
  • Pressing the upper chassis near the fan produces another tapping sound.
I shared videos with MSI support. MSI said the touchpad flexibility is normal for the Prestige 16 series, but my laptop is a Prestige 14. My request for a model-specific explanation remains unresolved.
MSI also declined my onsite service request under warranty and directed me to a nearby service centre, without specifying the reason for rejection.
Questions:
  • Do other Prestige 14 AI Evo owners experience similar issues?
  • Is this normal for this model, or could it indicate a fitment/hardware problem?
  • Has anyone received a resolution from MSI for similar symptoms?
I'm not assuming a manufacturing defect; I want to establish whether this behaviour is normal and get the laptop properly inspected if necessary.
Thanks!
Hi, you could try following MSI's instructions and take your laptop to a service center for inspection.
sadsv cdsc
Hi everyone,
Questions:
Thanks!
Hi everyone,
Questions:
Thanks!
Yes.
I came here searching for the exact same issue.
I just purchased "MSI Prestige 14 AI EVO C1MG 058IN". And I started to notice the "touchpad rattle". It feels like its producing a small "click" sound before actually pressing the button underneath it. I am quite in a mood to take it to some MSI service center, and get it opened and repaired for free under warranty. Might be the touchpad fixing bolts are lose? Or some kind of internal tension brackets are lose.
Although touchpad itself works fine, its just that while single/double click, this "click-click" sounds gives absolute low quality feel...
We as buyers never expect this low quality feel after spending a fortune on these things.
