MSI PRO B760M-A DDR4 - RX 6700 XT won't POST in primary PCIe x16 slot but works in secondary slot
paanayam215b402e7
Hi everyone,
I'm looking for help with a very unusual PCIe compatibility issue.
System
Motherboard: MSI PRO B760M-A DDR4
BIOS: Latest version
CPU: Intel Core i3-12100F
GPU: Gigabyte RX 6700 XT GAMING OC 12GB (Subvendor 1458:232D, VBIOS 020.002.000.019.000000)
PSU: Super Flower Leadex III 850W Gold
Problem The RX 6700 XT refuses to initialize in the primary CPU PCIe x16 slot. The VGA debug LED comes on briefly, then turns off, but I never get a normal POST display.
However:
GTX 1660 Super works perfectly in the primary slot.
RX 6700 XT works in the lower PCIe slot.
RX 6700 XT also works in another PC.
FurMark and OCCT both pass without artifacts or errors.
Things I've already tried
Latest BIOS
CMOS reset
UEFI and CSM
PCIe Gen Auto/Gen3/Gen4
Above 4G on/off
ReBAR on/off
ASPM on/off
Different PSU
Different HDMI/DP outputs
DDU and fresh AMD drivers
I also previously had the same issue on another MSI LGA1700 motherboard (MSI PRO H610M-E DDR4), so I'm wondering if this could be a firmware or GOP compatibility issue between MSI BIOS and this particular Gigabyte RX 6700 XT.
Has anyone seen something similar or knows of a beta BIOS or workaround?
big possibility it's an issue with VGA card or VGA bios, try to check with VGA card vendor as they may have a VGA FW solution available?
