alexn129602a6
- Jul 14, 2025
Main Board: MSI PRO B860-P WIFI (Serial number indicates Dec 2024 manufacture) (https://www.msi.com/Motherboard/PRO-B860-P-WIFI/Specification)
Bios Version: unknown, never booted (probably 7E41v1A10 or 7E41v1A20 according to production date)
Video Card/GPU, brand and exact model: NONE
PSU, brand and model: DEEPCOOL GamerStorm PK600D [R-PK600D-FA0B-WGEU]
12v rail Rating of listed PSU: 50A / 600W
CPU: Intel Core Ultra 5 235
Memory stick(s), brand and model: Patriot Viper Venom PVV532G640C32K DDR5 - 2x 16Gb
SSD/ HDD, brand and model: Samsung 990 EVO Plus 1TB
CPU COOLER: PcCooler RT400 BK
Raid Card: NONE
Sound Card: NONE
Keyboard: _USB Wired
Mouse: USB Wired
Any Additional PCIe cards installed into your system? NO
Display: Philips 245E1S
- Is it a TV?: No
- Connected to the motherboard: HDMI <-> HDMI
Compatibility Note:
According to MSI, the RAM and CPU are compatible (https://www.msi.com/Motherboard/PRO-B860-P-WIFI/support).
Power Connections:
24-pin ATX power connector is plugged in.
8-pin (CPU) power connector is plugged in.
The additional 4-pin (CPU) power connector is NOT connected.
Problem:
The BIOS does not load / The system fails to POST.
What Happens:
I assembled the PC from all new parts.
1. I press the power button.
2. The CPU cooler fan starts spinning.
3. At first start or after CMOS Clear the motherboard's EZ Debug LED briefly lights up RED (CPU).
4. The CPU LED turns off, and the YELLOW (DRAM) LED lights up for half a second, then turns off.
5. Then again CPU LED turn on for half a second and turns off.
6. The DRAM LED turns on and stays on for 5-10 sec, then turns off.
7. Repeats continuously (Red CPU LED -> Yellow DRAM LED -> Off) from point 5.
Additional Symptoms:
- The PC speaker remains silent (no beep codes).
- No USB power: Keyboard lights don't turn on, mouse laser doesn't light up.
- Monitor receives no signal.
Troubleshooting Performed:
1. RAM Slots: RAM sticks are installed in the recommended A2 & B2 slots.
2. RAM Configurations Tested:
- Switched to A1 & B1 slots - No change.
- Tested each stick individually in different slots - No change.
3. No RAM Test: Removed both RAM sticks and powered on:
- The yellow doesn't turn off.
- The PC speaker emits 3 long beeps.
The system is stuck in a boot loop failing at the CPU and DRAM initialization stages, with no video output or USB power.
Is it possible that support for my RAM was added in a later BIOS version?
Raid Card: NONE
Sound Card: NONE
Mouse: USB Wired
- Is it a TV?: No
Compatibility Note:
Power Connections:
Problem:
What Happens:
