MSI PRO e DEAD ?!?
didoop
Under is my post from tech powerup. So as last thing I post it on your forum.
I need some advice what to do ...
Today, I turned on my pc (see specs watched some news, facebook ,etc.)
I noticed that I have 1 left FAN for my PC from work (got from some new case, quiet with normal connecotr SYSFAN), so I wanted to install it because I needed more airflow .
So installed turned on , saw that POWERLED is not working. Checked and it was plugged. So I turned on AND no BEEP !
Tried agan NO BEEP (ofc normal booting sound of Corsair H50, etc) after 5 sec It rebooted and again no beep. It stays just like that (turned on).
ANY ideas ???
OFC no post , blank screen :)
today: Tried both GPUs separatedly , still nothing
Tried all RAMs seperately
Removed all driver
changed speaker
Changed GPU to Nvidia 6200LE
Checked CPU
Checked CPU pins
Cleared CMOS
Took out battery for CMOS
AND STILL NOTHING = Rly angly ... = Blank screen
Yea , working all fans , all leds (phase of CPU) , just NO POST NO BEEP - Turn on , reboot after 5 sec and stays that way.
BTW I planned to put this board to server in next 3 days, it was on my schelude , now, I can just watch dead Board with working Leds and Fans ...
PS: It's really possible to destroy board by connecting SYSFAN bad way ?
EDIT: as I can see , under me is same problem with MSI PRO e ... NICE
Thanks for your fast reply
Have you tried disconnecting the power cord, removing the battery and resetting the CMOS via the pins (should show how in your manual), reinsert battery, then check all power connections to mobo, ensure mobo attached firmly at all standoffs (to eliminate shorts), plug in and try to power up.
