So I have six GB of ddr3 memory installed on my core I7 930.
I'd just gotten off the phone with MSI they told me it was a memory problem as i had 1333 ram, it was meant to be oc'd and i need to do that if i want it to work rite.
the whole reason i called msi in the first place was because my computer will randomly give me a black screen where i have to force a hard reset. or a gray screen with vertical lines going down i.
so my question to you the MSI community is:
where can i learn to OC my mem on a x58 pro-e motherboard?
also what do you think is the problem ?
p.s its not the video card i tested it on another pc
also it is not an OS problem Ive tried multiple OS , EX Ubuntu , windows vista , windows 7 and even xp
PC SPEC"S
Intel core I7 930
6GB 1333 kingston memory
ATI HD 5750 1GB Video card
800wat psu
2x 1TB HDD
2x 24in lg displays
Thank you
Mathew V Holzschuh
PC SPEC"S
Intel core I7 930
800wat psu
2x 1TB HDD
2x 24in lg displays
Thank you
Mathew V Holzschuh
