- Apr 9, 2015
Hi every one its Stefan from RandomDesign again. Yes I am still from Germany.
This will be my second entry for the MSI PRO MOD Season 5
Lets have a look at the Specs first.
Motherboard: MSI Z270 Gaming M7
VGA: MSI GTX 980Ti Lightning
CPU: Intel I7 6700K
Memory: HyperX Predator DDR4 3200MHz 32GB (4x8GB)
SSD: 2x Hyperx Savage SSD 480GB
1x HyperX Predator PCIE SSD 480GB
PSU: Corsair AX1500i
Watercooling: Aplhacool
I am not that guy how shoots a lot of hardware pictures, because I think the result should speak for itself.
But nontheless, here is a picture of some of the water cooling stuff I will be using.
For this mod, the concept was a little different. This project was part of the MSI booth at the computex
this year. My goal was to build a mod, people can actually interact with. Thats why the idea was to build
a hybrid between a computer and a crane machine, so people where able to catch some goodies at the event.
In addition, the design should illustrate a stylized laboratory that could be used in space ships to investigate
unkown species or material.
Here are some pictures of the 3D model I created to check my design ideas.
This model also allowed me to place the hardware and make sure everything yould fit.
Then it was time to begin.
I started by cutting all the wooden panels into the right size.
Then I cut the front section. To make it look a bit more interesting, I cut all the edges.
Then I marked all openings ant cut them out.
This was the result. I was going for a design with two windows in the front. The top window is used to see inside the mod.
Here all the hardware and the mechanical parts will be visible.
The second, smaller window only allows a glance at a small part of the watercooling.
