I need help with an explanation of expansion possibilities and lanes on a MSI Pro Z790-A Max.
Right now I don't have a separate GPU and am using all 4 M2 slots of nvme which are almost full. So I have been looking at options for adding more NVMEs as they are faster for what I need in music production than sata connected SSDs. I came across NVME to PCIe adapters in single and quad form. For the quad ones, it says that every nvme installed in it needs its own x4 lane. So is it correct that in order to have 4 nvme on a quad adapter that on the Motherboard only the PCI_E1 which is a x16 will be able to do that? But if I did that, then I won't be able to use a good GPU in the future? My plan before really understanding all of this was to put it in the PCI_E3 slot. Based on the manual it says that slot is only a x4. Does that mean for this E3 slot only 1 nvme is possible and if this is the case, I should not even bother with a quad adapter and just get a single one?
Final question, would putting a NVME to PCIe adapter on the E3 slot with a 4TB nvme slow down any of my lanes such as my existing 4 M2 slot nvmes which are connected to the MB? Is there any system wide performance downside to expanding with 1 more nvme through the PCI_E3 slot?
Thank you for any help and explanation of how this works.
. So it seems if I want to get a GPU down the line then I need to be content with using only the slot 3 for only one more M2 and any other future needs I'd need to wait to upgrade my existing ones swapped out for larger sizes or make do with the slower SATA connected SSDs.
