pucho139158502d7
- Jul 1, 2023
I have bought an MSI PRO Z790-A Wifi and Im installing it as the manual says with a working power supply P850GM from Gigabyte (which I have already checked that are compatible).
When I'm trying to connect the 24-pin ATX_PWR1 and the 2 8-pin CPU_PWR1~2 the power is not reaching the motherboard (check image "24 and 8 pins connected")and I have checked the power supply separately with other motherboards and it is working correctly, so the power supply is not the issue.
If I connect only the 24-pin on the ATX_PWR1, the motherboard turns on successfully (check image 24 pin only connected). So I'm experiencing an issue regarding the CPU_PWR1~2.
Do you know what can be causing this issue? I don't know if its a defect of the motherboard or what can be done to fix this.
Thanks!
Thanks!
