msi rtx geforce 3060 ventus 3x
dpgingeric162502f5
Does anyone know why the above card is performing so poor with PP? The preview when editing is very choppy and sometimes stalls even when set to 1/8 resolution. My son's 2060 super card is smoother when I swapped them out. I updated my msi mother board to the latest firmware and still crappy performance. Is this just a poor card for video editing?
Alan J T
And what is PP besides what babies do in a Nappy
Alan J T
So your getting a 8GB card to replace e a 12 GB card for Premiere Pro it may well be worse for memory intensive work, 3060 Ti has More Cuda Cores but a lower Clock speed and less VRam.
And the 3060 should be about 30% faster than the 2080 in Adobe so you may have had a different problem.
dpgingeric162502f5
Maybe I'll send the card in to MSI. I suppose it could have an issue although Premiere pro is where I noticed it. Photoshop was nice and smooth editing.
I'll still try the 3060 ti but I'm going to make sure there's a good return policy if it does the same thing.
dpgingeric162502f5
Well I tried attaching a video. Even at 480p I got a message saying it's too big. Just picture a video preview stalling so much that it looks like a slideshow instead of a video. There's no fluid motion at all. I set to performance in the nvidia panel. It's 9:16 format, maybe that has something to do with it
Administrator
Upload it somewhere else like youtube, dropbox, mediafire and give a link to it
Try this: Run GPU-Z and open render test, and click run and while render test is running,
then run your app. and check if the issue will persist.
Administrator
Looks fine, appear to be some specified issue between this GPU Series and this specified application.
Try all tips from here:
dpgingeric162502f5
Thanks for your help. So it seems the card itself is fine, just something doesn't jive with the app? It's great with photoshop
Administrator
Etc: 2. Enable GPU Acceleration. and the rest within that application.
Check the link for details and rest of things.
Also ensure that you use latest adobe-premiere-pro patches and updates.
+ also update your GPU driver to the latest version 516.40:
Alan J T
Have seen a lot of people have problems with the program and seem to be lots of tutorial on how to improve it
With luck one will help
Out of interest what is you full system build.
fatedust
Survey Corps
FIRST LIEUTENANT
What's the video format? I will try to use some converter like VideoProc and convert the clip to MP4(H.264 codec) and import that file to try again. Also, when you preview the clip under Source panel (not under timeline), is it choppy as well?
Btw, Photoshop is more CPU intensive than GPU.
