Msi rx 590 side metal color change problem.
You mean the tarnishing of the I/O shield? Well, then nothing. if all works fine there is nothing to do.
mertceyhan92
Yea we can say so but its looks terrible. how can i buy that shield or if i send to service are they change that?
You can only buy a defective card and use the shield from it or rma the whole card (though doesn't make sense in my oppinion).
