For Battery Optimizer in MSI Center Pro, there are two options:
Balanced: Charge battery when under 70%, stop at 80%
Best for Battery: Charge battery when under 50%, stop at 60%
When I select the latter, it charges the laptop to 79%, not 60%. I don't know whether this issue is specific to this model laptop only, in which case the BIOS needs to be fixed.
It would be nice if there was the option to configure the lower and higher setting as you wish, using slider bars. The Dell XPS does this. So you can set charging to start when the battery drops below 50% and to stop charging when it hits 55%, for example.
