MSI Sword 16 HX B14V - Severe DPC Latency, audio crackling and micro-stutters (wdf01000.sys / ntoskrnl)
ostallica8156102dc
Hello everyone,
I am experiencing a persistent issue with audio playback (especially on YouTube and media streaming) on my laptop. The audio stutters and has micro-clicks or dropouts every few seconds.
I ran LatencyMon, and it states that my system is having trouble handling real-time audio, pointing to high DPC/ISR latency routines.
Key details from LatencyMon:
  • Highest reported ISR execution time: High spikes caused by wdf01000.sys (Kernel Mode Driver Framework).
  • Highest reported DPC execution time: High spikes caused by ntoskrnl.exe.
  • Conclusion: Buffer underruns appearing as drop outs, clicks, or pops.
I've already tried basic power plan adjustments, but the issue persists. Could this be related to a specific driver conflict (Chipset, Realtek Audio, or Wi-Fi/LAN) or a BIOS limitation?
Any advice or known fixes for the MSI Sword series would be greatly appreciated. Thanks in advance!
System specs:
  • OS: Windows 11 LTSC
  • BIOS Version: E15P2IMS.110
  • RAM: 32 GB
  • Storage: ADATA LEGEND 700 SSD
I did what was mentioned in point 3. At the beginning, when I started listening to music on YouTube, it sounded normal, but after about 15 minutes, the glitching started again. I ruled out point 1 because I don't have Norton, I use Avast. I still have to try point 2, but honestly, I'm not sure about it. I'm attaching a video.
You might want to try Step 2; this is information I obtained from MSI customer support: "[Troubleshooting] Audio Crackling or Static Noise."
I have tried step 2, I downloaded and installed the Nahimic APO 5.0.6 file exactly as the guide says, but I have my doubts about whether it installed or not.
Check the screenshot, shouldn't it say 5.0.6?
To be sure, I first did step 3 again, and when installing the Nahimic APO, I used the downloaded version 5.0.6 file.The problem still persists now, but with less frequency. I don't know what else to do, it's annoying not being able to listen to music normally on YouTube =(
How hot does the CPU run when idle and when performing these tasks?
Download hardware monitor and check your 14700HX P-Cores, E-Cores, Temperatures, Frequencies and Power usage.
https://www.cpuid.com/softwares/hwmonitor.html
And here is an example screenshot of what to look at, note my CPU is only showing the P-Cores, your one will show E-Cores too.
If when watching videos or performing tasks the CPU is running a high temperature that is 95 degC or above and the frequency stays low on the P-cores whilst under said load, and this when checked with latency monitor coincides with your audio issue, then it may be the result of the CPU running too hot. What happens is it attempts to slow itself down by introducing wait states along the process chain, think of it as the CPU taking a break momentarily. <This action is what can cause audio glitches / stuttering.
But do you have issues in gaming too?
And did the laptop work previously at some point / when did the issues start?
When I play games, it runs normally, I haven't noticed those stutters. The laptop used to work fine. Sometimes I think it might be the SSD, because whenever I had to format the laptop, when installing everything from scratch everything worked properly, there were no audio stutters when listening to music on YouTube, and after a while, the glitching would start again. Maybe 3 months ago I changed the thermal paste on the processor and GPU for maintenance, plus I use a cooling pad with two fans to help with cooling as well.
With those temps and what you mention it's probably the audio enhancements / drivers, you have a few active all at the same time which is part of the laptop / Windows.
- Intel SST (Intel smart sound technology driver)
- Realtek (driver)
- Nahimic (software)
- Windows Audio enhancements (software)
Try disabling the audio enhancements + spatial sound in Windows Sound properties, for the laptop (My screenshot shows my monitor as the audio output)
This one will impact the Intel SST function, not required, its something that also passes sound through the CPU for some additional offloading / enhancements but can be problematic.
Other than that, I would say go the simple route of being basic, Uninstall Nahimic see if it helps.
Disabling audio enhancements from the window you showed stopped the glitching (spatial sound was already disabled and I just left it like that), but the audio isn't as pleasant anymore. It sounds very low, you lose the laptop's essence, I'd say haha.
So I'll have to use it like this =(
Hello everyone,
System specs:
  • RAM: 32 GB
Go into the BIOS and check if VMD is enabled. If it is, disable it and reinstall Windows. That’s how I fixed the issue. You may need to switch to Advanced Mode in the BIOS settings to find the VMD option. Check online for instructions on how to enter Advanced Mode.
When I disabled Windows audio enhancements (spatial sound was already disabled), the glitching stopped. I enabled them again afterward and it started working normally without dropouts. Very, very rarely the audio stutters just once (mostly when I open an application or when a background process is running), giving a small hitch, but nothing annoying compared to before.If it happens to fail again, I will try the last two solutions mentioned in the thread. Thank you all very much for the help! 🫂
It's not really helpful. How in this century we can fight with drivers and different sound settings? MSI creates a lot of messy drivers Nahimic, Intel, Realtek audio, etc.- making it more complicated, so things just get broken!
The above countermeasures are effective. You can give them a try to see whether the issue is resolved.
Hi, I've reviewed the information shared by other users above. Overall, the issue can be addressed from the following two aspects:
Official MSI information: https://www.msi.com/faq/faq-11152
  1. Reinstall all audio drivers and applications: https://www.msi.com/faq/notebook-3640
Having seen your message, you may have already completed the above steps. If you're willing, you can export the system information from MSI Center so we can review the installation status of your drivers and applications. It would also be helpful if you could share a video of the crackling sound.
If you have any other concerns and the issue remains unresolved after completing these steps, we recommend contacting MSI official technical support or customer service, or having the device inspected offline.
